586,132 active members*
2,652 visitors online*
IndustryArena Forum > Other Machines > PCB milling > Interface to the iGaging “Snap Depth” Mini Depth Gauge Digital indicator
    Dec 2011
    10
    Hi!
    I’m a newcomer to CAD/CAM and this forum. My interest is to produce PCB for hobby/research use. I have two questions:
    1. Do anybody know anything about on how to interface the iGaging “Snap Depth” Mini Depth Gauge Digital indicator (iGaging Snap Gauge), see below.
    I have read the very good article at 21 Bit Protocol Scales, shumatech.com.
    Even if the circuit layout of this particular device not is equivalent to the one in the article I suspect that the principally uses the same IC and therefore protocol solution. However of the four interface pins one is connected to ground (battery minus).
    I expected at least one of the remaining pins would give the VCC voltage (battery voltage). But I cannot detect any voltage at all. It doesn’t matter how I measure between the pins all have a voltage of zero (measured with hi Z DM). I understand that I probably need an external clock. But on witch of the remaining three pins?
    Another question is how high the clock frequency can go. The article mentioned 9 KHz, but the Chinese regularly goes up to 90 KHz and above! So if anybody has any information on this I would be grateful.
    2. The other question I have is about ATC (Automatic Tool Change). I would like to incorporate that in my CNC miller. The most troublesome part is where to get or how to construct the chuck and still get the accuracy (run out) needed for PCB milling. Anybody that can give me some links or point me in any direction?
    Regards
    Bo, SM6FIE
    Apr 2003
    550
    Actually on that site or the Yahoo group for the DRO the I gaging format is discussed in detail. The new DRO 550 supports the Igaging format.
    With a little digging I am sure you can find it. I have some pic code somewhere that was supposed to convert the QC100 to an I gaging to standard Chinese scale format but it was untested.
    I can dig up the code(it wasn't written by me) if you want it...
    Garry
    Dec 2011
    10
    Thanks for help, solution found...
    Thanks Garry!
    Sorry for late reply but work duties has taken all the time. I did find the information I was looking for. It turned out that the protocol was a slight variation of the 21 bits Chinese protocol. I made a protocol converter by using a PIC with a USB connection and can now conveniently get my data into my PC. Thanks for the help much appreciated!
    Regards
    Bo, SM6FIE
  1. Syil X4+ probe or tool depth gauge wiring connections
    By Mac Tech in forum Syil Products
    Last Post: 08-25-2011, 12:53 PM
  2. Digital Height Gauge...
    By pete from TN in forum Benchtop Machines
    Last Post: 02-23-2011, 05:07 AM
  3. TTS DIGITAL HEIGHT GAUGE
    By keen in forum Tormach Personal CNC Mill
    Last Post: 03-15-2009, 05:03 PM
  4. How to Add Digital Depth Guage To Drill Press
    By cbrussell in forum Uncategorised MetalWorking Machines
    Last Post: 01-31-2009, 09:01 PM
  5. Mitutoyo digital indicator interfacing
    By daedalus in forum Mechanical Calculations/Engineering Design
    Last Post: 11-05-2006, 02:33 AM
