586,608 active members*
3,579 visitors online*
    Mar 2009
    76
    STAR SR20 RIII
    Has anyone noticed that G87 doesn't work on the Star SR20 RIII? I have heard that the cross peck drilling cycle doesn't work on this machine. If anyone knows for a fact either way I'd appreciate to hear from you.
    Sep 2011
    261
    Im not sure about the G87 but if you have a floating holder this is a good working macro taping program:
    T0303(4-40 CROSS TAP)
    G50W-.194
    #100=350 (RPM)
    #101=.025 (FEED/pitch)
    #102=[#100*#101]
    G0 G98 X# Z# M23S#100 (cross tool on clockwise)
    C0. (or c whatever)
    G4U.5
    G1X-.36F#102 (X end depth)
    M24S#100 (cross tool CCW)
    G4P5
    X.3 (X above stock)
    G0X1.496 T0 M25 (X home, cross tool off)
    G50W.194
    M51
    If you break a tap reduce the feed from actual to 90%, if that breaks reduce feed to 80%. Actual pitch usually works but a couple times ive had to use 80%
    Let me know if that works for you
    CNC Product Manager / Training Consultant
    Oct 2011
    I don't think I've ever heard a more ridiculous statement. G87 most certainly works.
    Mar 2008
    443
    It's been over 4 years since I last programmed, setup or ran one of those, so forgive my probably ignorance.
    It is not unusual for Star to have modified the basic G87 into something like a G287 using the available Fanuc custom G-code function. That's especially likely if the application is needed for the cross-working tools that have to peck in the Y axis. Check your documentation.
    Aug 2005
    G87 cross pecking cycle
    I had this problem years back with a SR-20 RII. Turns out when I programed
    G87 it seemed like it just went to the bottom of the z stroke in rapid. (and of course the drill broke) Turns out it was a parameter setting. It was set for high speed pecking. So I suggest checking out your parameter manual or calling you Star Rep to find out what parameter to change. Hope this helps.
    Jun 2006
    59
    Check your coordinate system. On the RII there are G17, G18, G19, G117, G118, and G119 CS's. It will do exactly as you say if you don't change to the correct coordinate system. I think that it's G118 if you're using 3100-3500.
    Star SR20RII/Fanuc 18i, DMG CTX310V4/Fanuc 32i, DMG CTX310ECO/Siemens 8400, Mori NV5000/MAPS, Bridgeport 760/Fanuc 18i, Kiamaster 4NEII60/Fanuc 3t;Partmaker, Gibbscam
  1. THK SR20 linear guide question
    By vpl in forum DIY CNC Router Table Machines
    Last Post: 10-25-2010, 12:18 AM
  2. Star SR20 Macro question
    By jrob69 in forum Jewelry Design Software
    Last Post: 10-19-2009, 01:26 AM
  3. SR20 STAR Lathe
    By jrob69 in forum CNC Swiss Screw Machines
    Last Post: 03-13-2009, 02:19 AM
  4. Star SR20
    By jrob69 in forum Employment Opportunity
    Last Post: 08-21-2008, 05:52 AM
  5. Looking for THK SR20 Bearings (cars)
    By southernexplore in forum Linear and Rotary Motion
    Last Post: 01-31-2006, 12:25 PM
