586,403 active members*
2,574 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > How are you changing tools? Multiple spindles? ATC? Manual?
Results 1 to 17 of 17
    Mar 2005
    266
    Had the chance to earn some money cutting wood on a router but didn't work out as my quote was beaten by *alot* unfortunately. However I still dont have a CNC router and when/if I get one tool changes will be something I need to figure out.
    Buying a machine capable of ATC is out of the question for me. Any money work I would do would only be part time so I would not be able to pay off a commercial machine or make a profit for my time which is important of course.
    ATC spindles are around $3000+ each. Again not a real appealing option considering the entire router would cost less than this even when using decent components.
    So.. I think the only 2 good options left would be to use multiple spindles. Either by actually having 2-3 spindles on the machine at all times (preferred) or by making some kind of quick change for the router spindles.
    If using 2 spindles on the machine I am not sure how to program it but maybe some kind of relay to route the Z axis step and dir signals to different spindles motion controllers could be worked out so that 1 could be used at a time with MACH. Maybe its easier than this. I dont know how or if mach is designed to use more than 1 spindle.
    "Quick change tooling" by actually swapping spindles is doable but *alot* of work and not very good for time savings IMO but it does represent another possibility.
    ATC? Sounds great but how can I get ATC without spending $1000's? or being slooow.
    Jul 2006
    1256
    ATC
    Where can you get an ATC spindle for $3000.They are usually 10 to 15 grand.
    larry
    L GALILEO THE EPOXY SURFACE PLATE IS FLAT
    Mar 2005
    266
    Dont recall where I saw spindles for $3000.00 if I do I will post a link but kelinginc.net has 2 for $4000+
    CNC Spindle and Controller
    Dec 2010
    634
    Note: I am a hobbyist, I do not work in a production environment.
    I've been doing my tool changes manually using the tool change macro's in Ger21's screenset.
    With those macros, once you change tools, the machine moves the spindle to a fixed sensor plate to get a new tool length offset for the new tool.
    This whole process takes roughly a minute which isn't bad but, it does mean that if you're doing something else while the machine is plugging along, you have to be near by enough to change tools when necessary.
    I try and minimize tool changes through smart programming of tool paths but some things are just difficult and it all depends on what you're doing.
    -Andy B.
    http://www.birkonium.com CNC for Luthiers and Industry http://banduramaker.blogspot.com
    Feb 2009
    2143
    Auto touch off, per the suggestion with Ger21's screenset. And/or something like the Tormach Tooling System chucks that give you repeatable Z placement with manual tool changes. TTS is R8 only, but maybe you could do something similar on a router?
    CAD, CAM, Scanning, Modelling, Machining and more. http://www.mcpii.com/3dservices.html
    Mar 2011
    584
    I'm planning on mounting a drill on a slide on the side of my router mount and actuate it down with a bimba cylinder to drill holes with. Then I could use cheap drill bits vs expensive router bits and no worries about changing collets and stuff. I know this doesn't really answer your question but it may give you something to think about.
    Aug 2011
    999
    I am completely manual which is O.K. for my one-off hobby projects.
    But I saw the Youtube video of Andrej (the guy behind the the Planet-CNC USB controller) who is using a Kress spindle with automatic tool change. Not sure what pneumatic adapter he is using but it does not look like a multi-1000-dollar solution. It may be worthwhile to contact him:
    [ame=http://www.youtube.com/watch?v=Hgyq3JYlBmw]CNC USB Controller Mk2 - Automatic Tool Changer (ATC) - YouTube[/ame]
    Quote Originally Posted by JerryBurks View Post
    600 Euro + 50 Euro per tool + collets = ~$1200 + the Kress spindle for 5 tools, and you're limited to 1/4" tools or smaller.
    Tool Changer
    Tool Holder
    Jan 2011
    242
    Avenger Cartridge ATC system
    I'd also look into contacting a Chinese CNC supplier and see if they'd be willing to sell you the mechanical parts. You'd still need the programming done in Mach3 so everything behaved properly but it could be a less expensive route.
    Oct 2006
    735
    For my machine 2 I built it with 2 Z axis. So the idea would be to have a second spindle mounted to the other axis and have 2 tools avaliable. Although I have yet to fit the second VFD spindle. Maybe some day.
    b.
    Sep 2012
    228
    I believe CAmaster tools uses a setup where they have 2 addtionional routers with bits... attached to their z axis.
    Anyone figure out how they do it?
    Can it be done with Mach 3 software?
    Jun 2012
    25
    I think that is awesome. I will have to do some research on the ATC holders. Very interesting. I am sure some designs are out there but, cost is definite probably going to be high.
    Dec 2006
    8
    This one from IMService is pretty affordable. IMService ATC - Automatic Tool Changer for CNC Mill or Router
    - - - Updated - - -
    This one from IMService is pretty affordable. http://www.cadcamcadcam.com/toolchanger.aspx
    15362
    This is a old posting, but still good information in it
    This machine now has 2 spindles & around 24 tools each spindle has its own tool rack, these spindles were around $2600 30 taper
    https://www.youtube.com/watch?featur...&v=-V10EycGAU8
    Mactec54
    Jul 2005
    46
    What?! A $2600 atc 30-taper spindle? What kind? Where?
    Chinese from Keling.
    15362
    NardisAmps
    He got his spindles direct from China, the spindles he brought are very good quality
    Gerry I don't think the Keling spindles would be of the same quality as what he is using
    Mactec54
  1. Multiple spindles on Mach 3 mill
    By jomijen in forum Mach Mill
    Last Post: 01-31-2015, 07:11 AM
  2. Rhinocam and multiple spindles and or multiple tables?
    By brett gallmeyer in forum Rhinocam
    Last Post: 02-23-2011, 08:30 PM
  3. changing part setup for multiple ops
    By Captdave in forum HURCO
    Last Post: 05-23-2010, 03:04 PM
  4. Multiple tools for truemill
    By qmas99 in forum Surfcam
    Last Post: 10-14-2008, 07:24 PM
  5. Multiple Spindles (Routers)
    By ynnek in forum DIY CNC Router Table Machines
    Last Post: 04-26-2008, 06:37 AM
