586,409 active members*
3,019 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > Spindle turns on unexpectedly!
    Apr 2003
    637
    Exclamation Spindle turns on unexpectedly!
    I saw this twice yesterday and I’ve taken the machine off line until I find a solution. It’s an old (1995) Partner 1 enclosed bed mill with a C5 control.
    Both times the spindle turned on when the operator hit the Z button in HDW mode. Not good.
    Any suggestions on where to look (other than a new machine) would be appreciated.
    Oct 2008
    427
    Do you have a remote keyboard plugged in? If so, try it again with the keyboard unplugged.
    If you have a stuck ALT key, the F3 button in handwheel for the Z axis would give the same command as the CW button.
    This problem could also be caused by a bad Keypad Encoder Board.
    Here are the keyboard replacements for all the front panel buttons:
    To Replace Front Panel Buttons
    Alt + F1 Spindle Stop
    Alt + F2 E-Stop
    Alt + F3 Clockwise
    Alt + F4 Feed Hold
    Alt + F5 Counter-Clockwise
    Alt + F6 Cycle Start
    Alt + F7 Mist
    Alt + F8 Tool Reset
    Alt + F9 Flood
    Alt + F10 Reset (may have to press the Reset button at the same time)
    Feed Rate Over-ride Spindle Over-ride
    Alt + A 0% Alt + 1 0%
    Alt + S 10% Alt + 2 10%
    Alt + D 20% Alt + 3 20%
    Alt + F 30% Alt + 4 30%
    Alt + G 40% Alt + 5 40%
    Alt + H 50% Alt + 6 50%
    Alt + J 60% Alt + 7 60%
    Alt + K 70% Alt + 8 70%
    Alt + Z 80% Alt + Q 80%
    Alt + X 90% Alt + W 90%
    Alt + C 100% Alt + E 100%
    Alt + V 110% Alt + R 110%
    Alt + B 120% Alt + T 120%
    Alt + N 130% Alt + Y 130%
    Alt + M 140% Alt + U 140%
    Alt + < 150% Alt + I 150%
    (Sorry, I can't get the formatting on the over-ride chart to work correctly)
    Apr 2003
    637
    ZZZZ, thanks but there is no way to connect a keyboard. Where is the keypad Encoder board located? And where can I find a replacement? The problem is intermittent. Maybe it’s time to dump this dog.
    Oct 2008
    427
    The Keypad Encoder Board is attached to the backside of the alpha-numeric keypad inside the front-panel. The connector for the external keyboard is on the Keypad Encoder Board.
    Some machines have a jumper cable from the side of the front-panel to that connector.
    Sep 2010
    529
    Here is a picture of the inside of my Centurion V control, the board in the left portion of the pictures is the keyboard encoder board, you can see the adapter and cable I used to bring the connection to the side of the cabinet.
    My machine works just fine until I plug this cable in, evidently once plugged in it acts as an antenna and starts acting all sorts of weird, spindle turns on and off, machine moves at will, keys on the existing keyboard don't work at all, or take twenty hits to actually register. I panicked when I first hooked it up thinking the computer had gone haywire.... but disconnecting the wire has solved the issue... the factory version must have special shielding or something.... I haven't needed to use it since, so haven't delved into solving the problem.
  1. CNC spindle motor turns on after computer boot
    By oisyaot in forum Benchtop Machines
    Last Post: 11-20-2011, 08:34 PM
  2. 4th axis turns to many turns
    By cob in forum Mastercam
    Last Post: 02-16-2009, 07:19 PM
  3. What turns 4th axis 'on' in MCX?
    By Donkey Hotey in forum Mastercam
    Last Post: 03-12-2008, 01:37 AM
  4. I'm done, but nothing turns
    By pbarsalou in forum DIY CNC Router Table Machines
    Last Post: 04-08-2007, 05:15 AM
  5. Okuma Vmc ,g80 Turns Spindle Off
    By qmas99 in forum G-Code Programing
    Last Post: 05-20-2006, 01:34 PM
