586,555 active members*
3,537 visitors online*
    Nov 2009
    159
    New plasma "Loadout" for 2012 from Bulltear industries
    Over the last couple of years building CNC plasma tables and selling CNC plasma gantry kits we have had great success with a large install base. We constantly get asked the question "Will it route". With the older gantry kits the answer is simply "No it will not route it wasnt built for routing".
    The end of 2011 brought us to a point where we thought "Hey we have large multi axis CNC's can we make a no compromise solution to CNC plasma cutting, routing and duties and with no maintenance?". This brought us to the drawing board and through rigorous testing of components 1/4 scale we have concluded that the full scale system will perform extremely well under many many situations. We looked at all types for rails, configurations and issues here and abroad. The load values, the weight, the customer questions, the accuracy and the general pain it is to maintenance anything on your multi thousand dollar machine.
    We knew from experience that if machine components arent made on quality precision equipment they will present the customer with issues. CNC plasma can be pretty accurate however building the components that make up the CNC plasma cutter should be made with extreme precision and without compromise of quality and alignment. We found the only way to guarantee quality and precision is to build a platform from the ground up using CNC machining centers and precision programming and fixturing methods.
    Lets go into detail
    The Z axis;
    The Z axis must be able to handle side loads as well as vertical loads. We are able to achieve this by using a large hardened and ground precision stainless steel 3/4 screw and machining our own zero backlash nuts. This gives us ultimate rigidity in the vertical plane. Next we added hardened and ground stainless steel 1.000" large shafting with a generous spacing and adjustable preload linear trucks to add a supreme side to side load. We coupled all this together in 3/4" thick material making the ultimate Z axis for plasma cutting and routing.
    The Y axis;
    The Y axis was built with large 4" tall railing adjustable preload (adjusted from our factory) HD Viper rail. The components were machined from solid blocks and double bearings guarantee load values, concentricity and planar parallelism. Large wide gear rack and a smooth motion pinion on the Y axis. 1/2" hardened steel shaft and 2 flats and 2 set screws on the gear drive. No loose gears! Accuracy is .0004"
    The X axis;
    The X axis is where we really added rigidity and torque. The X axis is built from the large 4" tall adjustable preload (adjusted from our factory) HD Viper rail. The components were machined from solid blocks and double bearings guarantee load values, concentricity and planar parallelism. It is a true dual driven axis with large wide gear rack and smooth motion pinion gears with 1/2" hardened steel shaft and 2 flats and 2 set screws on the gear drives. No loose gears! Accuracy is .0004"
    Large cable carrier is also included in the gantry kits and installed on the tables for any and all accessories.
    *spy pics
    Now featuring Plasmaland online
    Nov 2009
    159
    Dec 2011
    do these have gear reductions? belt? ratio? what electronic do you use? THC? looks like a great system! would really like some more info.
    thanks
    Oct 2005
    378
    Sonic03cobra, I was interested in the gear reduction unit as well. I did a search and turned up this site. Unfortunately no gear reduction units for sale but they do offer some other parts.
    Gantry kits, Plasmaland
    Magma-joe
    Nov 2009
    159
    Timing belt reduction...no gear boxes (we have done those.....never again, downward spiral there!). Candcnc electronics! You can purchase minus electronics if you wish. Mag-Lok torch breakaway system...more info soon (built and machined in house on multi axis machining and turning centers)
    Nov 2009
    159
    Custom sizes available 4x9
  1. Bulltear Industries support forum
    By cncadmin in forum Bulltear Industries Support Forum
    Last Post: 11-26-2009, 07:56 AM
  2. "Capacitor Industries" Experience
    By ww_kayak in forum Phase Converters
    Last Post: 07-19-2007, 09:35 PM
