586,508 active members*
3,479 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > x2 spindle motor replacement options ?
Page 2 of 7 1234
Results 21 to 40 of 133
  1. #21
    24223
    Many use the KB or Baldor equivalent SCR drives, but take the 2.5HP with a pinch of salt,
    If you compare the size with an industrial 2.5hp brushed, they are usually much larger,
    also it takes a well designed (expensive) DC brushed motor that will run at 6000rpm?
    Al.
  2. #22
    i sort of figured that might be the case , heres one off the top of the ebay page , there are loads that are similar TREADMILL PERMANENT MAGNET MOTOR 130V DC 2.5HP 18 amps | eBay
    A poet knows no boundary yet he is bound to the boundaries of ones own mind !! ........
  3. #23
    24223
    One like this looks decent construction 360388512832.
    If you are lucky, a Leeson or a Baldor T.M. motor sometimes come up.
    Or look for an older Gettys or Fanuc DC servo motor, they also have tachs for using the feedback option.
    Al.
  4. #24
    24223
    Quote Originally Posted by dertsap View Post
    i sort of figured that might be the case , heres one off the top of the ebay page [/url]
    Forgot to mention, that one and many such cheaper ones designed specifically for T.M. operation are designed uni-directional.
    It is marked CW rotation.
    Al.
  5. #25
    Thanks Al , good point and I'll definitely keep that in mind ,
    that particular motor was just the first one on the top of the listings just to use as an example .
    I'll see what the new board does , and if its an improvement like the other guys claim then I'll run with it , Then it can buy me some time to find something better
  6. #26
    Man ! What an abortion ! LOL !
    the control board on the mill looks nothing like anything that I can find on the net .
    I've adjusted the pots back and forth on the board until i could hear that sweet spot where it sounds absolutely clean . it now runs much better and smoother at high and low rpm , it still needs a warm up in low gear before i cross it into high but its cool outside so the spindle bearings are going to be a bit stiff . it beyond me if the warm up is necessary on anyone elses machine but considering the tar they use for bearing grease then I'd assume it's typical
  7. #27
    24223
    I'm assuming you are still using the factory original motor and drive? or are you using the KB drive?
    Al.
  8. #28
    oh ya !
    yep still the factory , I'll probably get the other stuff within the next couple of weeks , I've got the board coming from one place the hp resistor from another and a potentiometer from yet another .
    at least as it stands I feel like i can trust it enough that i can play a little more rough
  9. #29
    looks as though that has done the trick for now , I'm not going animal on the cuts but I can push it pretty well with a small 1/4" end mill , I could hear the tool working hard and the tool is being pushed well beyond its normal capabilities , which surprised me (not bad for a cheap tool ) , but the spindle wasn't bogging .
    I still managed to stall the spindle and popped a fuse before breaking the tool so its still weak in my opinion . I think I've figured out the machine's limits .
    With lighter cuts and my typical style of machining then i can cut out a part quickly and accurately ,
    I've looked over a crap load of videos on line and in comparison to what I'm doing then I can machine out a part at a much quicker rate as it is , but then most of the machining processes in the videos weren't what I call optimal . there were a few pretty cool video's to watch though and I've got a couple new ideas for add-on's
  10. #30
    Jun 2010
    1414
    So you did the mod to the board and were successful? I would be happy to try this out. I am pretty new to motors & controllers, but I can follow any kind of diagram. The board on e-bay looks very different to what is on the pictures, but I guess were looking at the back of it?
    K B Electronics Inc Speed Control KBLC-19PM | eBay
  11. #31
    no mod yet , still waiting to get the board which will be here in a couple weeks , the improvement so far was in tweaking of the stock board
  12. #32
    Jun 2010
    1414
    I didn't catch, but what did you improve upon the stop board?
  13. #33
    Nov 2010
    291
    After tweaking my stock board my belt slips before the motor stalls or trips the breaker.
    I don't run it that much or extremely hard but I like to push it when it runs.
    I have a treadmill motor and MC-60 stock treadmill controller waiting for the mill if it dies.
    My second option is the KBLC-19 or -120 like you are doing, I have read a lot of good about it.
  14. #34
    Jun 2010
    1414
    I only stall drilling holes. I have yet to stall while milling anything, but I only mill aluminum and copper, and I am very gentle with that.
  15. #35
    Mar 2007
    51
    Al.
    And if you look closer at the label, it's rated 1.5HP continuous, and requires external fan unit for cooling.
  16. #36
    the kblc board provided the world of difference , i have no way of figuring out the increase in torque but lets say its a freakin far cry from what it was previously , previously it would take a 5 minute warm up in low then i could change over to high , otherwise the motor would not turn the spindle in high what so ever when cold , and it would inevitably blow yet another fuse .
    Right now my unheated workshop is the coldest it's been all winter at +6 to 7 deg Celsius , at cold start the kb board pulls to full rpm without hesitation on high , after 1/2 hr of running the board is cold and the spindle motor has a slight warmth to it which is maybe a degree or two warmer than my hand . Now i just need to take the time to finish tweaking and then box in the electronics
    as for rpm change , I'd say there's some but i won't know till i put a tach to it , besides more rpm isn't as much of concern , my concern is reliable torque which appears to be a problem now conquered ,
    the true test will be in the cutting but judging by the change in the performance already then i think it'll do , I can only expect so much from a little toy
  17. #37
    Jun 2010
    1414
    Can you take some pics of the setup? How you wired it etc?
  18. #38
    How to wire it is in the link that i gave you. The only change is that the motor connects to a+ and a- .
  19. #39
    Jun 2010
    1414
    This one?
  20. #40
    24223
    Also as I noted earlier, if reversing the armature leads after power has been applied, use the I1 & I2 terminals to allow the drive to go through the accel after reversing, otherwise it is full on.
    They should be shorted when drive is off, also if there is a centre off between fwd and rev, this will stop any creep that may occur from any small command by pot etc.
    You could also leave the pot at a certain run position and inhibit by the I1 I2 and when released will acell up to the pot position.
    Not to be used for tool changes etc however.
    Al.
Page 2 of 7 1234
  1. Replies: 1
    Last Post: 03-06-2013, 05:19 AM
  2. X2 Spindle AC Motor Options (3 Phase)
    By Nixxk in forum Benchtop Machines
    Last Post: 03-15-2012, 10:49 PM
  3. Spindle motor options
    By awetmore in forum Taig Mills / Lathes
    Last Post: 02-16-2010, 09:21 PM
  4. SPINDLE/MOTOR OPTIONS?
    By cornbinder23 in forum Benchtop Machines
    Last Post: 01-16-2010, 10:56 PM
  5. Spindle Motor replacement?
    By Trapper14 in forum Mini Lathe
    Last Post: 03-10-2006, 11:48 PM
