586,331 active members*
4,943 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Stock Manager problem
    Dec 2011
    Trying to do the Assembly 2 Tutorial from the Camworks Mill and Turn tutorial that comes with Camworks. I am using the sample file that is included with Camworks called MILLASM_2.SLDASM. When I use the Stock Manager to increase the value of Z to .1 the stock grows in the X direction and not in the Z direction. What setting allows you to set the correct X,Y and Z directions to control stock size?
    Sep 2003
    35
    Hi Joesph,
    The stock manager is using the SolidWorks XYZ in the stock definition. So it depends on how your model is placed in regards to that. I normally glance at the 3D gnom in the lower left of the screen to see which axis to apply extra material to.
    Dec 2011
    Thanks Lars. Never would have figured that out without your help.
  1. Material Manager/Purchasing Manager - IL
    By MachiningJobs in forum Employment Opportunity
    Last Post: 05-23-2011, 04:04 PM
  2. Problem with Esprit Lathe Stock
    By bigping77 in forum Esprit
    Last Post: 02-28-2011, 02:19 PM
  3. stock size posting problem
    By basim in forum Post Processors for MC
    Last Post: 12-19-2009, 12:33 AM
  4. problem Bobcad V23 post manager
    By paulorockmacedo in forum BobCad-Cam
    Last Post: 01-19-2009, 02:27 AM
  5. 32MP Memory Manager transfer problem
    By RoboVin in forum Fadal
    Last Post: 08-21-2006, 02:53 PM
