586,682 active members*
2,738 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Mini Lathe > What bearing brand for 7x headstock upgrade?
    May 2009
    7
    Post What bearing brand for 7x headstock upgrade?
    I'm thinking of doing the roller bearing upgrade to the headstock of my 7x10 lathe before I convert it to CNC. Any advice on bearing brand? Timken? NTN? NSK? Bower? Any I should specifically avoid? I only have budget for standard precision bearings, but I'm a little concerned about LMS's unnamed tapered roller bearings.
    K-
    May 2010
    When i did the taperd roller bearing mod to my lathe during the conversion,i was also a bit dubious about useing the cheep un named brands so i used SKF's but i would think any of the brands you named would be fine. replaceing the spindle bearings is the kind of job you only want to do once.
    regards
    Simon
    May 2009
    7
    Thanks Simon, I ended up ordering a pair of Timken bearings. I also decided to order the metal gear upgrade kit from LMS. It comes with the spindle puller, and I agree, probably a good idea to go in there once and be done.
    May 2005
    3920
    A good choice.
    Quote Originally Posted by kdaniel32 View Post
    For run of the mill bearings sticking with the larger brand nanpmes makes good sense. It is not unusual for their standard bearings to exceed specs.
    As for going in there once and being done with it, you can only hope! It doesn't take much to damage a bearing. When it comes time to open the bearing package make like a doctor and keep everything in the work area clean and shinny. You don't want contamination to get in the bearing.
    The other thing to watch out for is the tight fit of the front inner race. These are often shrunk on. A toaster oven and a freezer may come in handy.
  1. Replies: 8
    Last Post: 10-26-2014, 06:01 PM
  2. MT1 into taig headstock
    By chris123 in forum Taig Mills / Lathes
    Last Post: 10-19-2010, 12:16 PM
  3. Headstock Bearing for Top Turn CNC-406
    By jime in forum Uncategorised MetalWorking Machines
    Last Post: 11-26-2007, 03:30 AM
  4. Tapered roller bearing vs. angular contact bearing
    By boyvox in forum Linear and Rotary Motion
    Last Post: 01-25-2007, 09:49 PM
  5. X2 spindle bearing upgrade
    By cncuser1 in forum Benchtop Machines
    Last Post: 01-05-2007, 01:22 AM
