Hi all
Not sure if this is the right place to post this or not.. but here go's
I'm having troubles at setting up Type 2 G71 Canned cycles witch i need as there is pocketing in the Z axis
The machines errors out 065 when it runs the first line of the roughing cycle
HTML Code:
% ' This program Machines the Z profile
'Material 2in out 65mm from chuck
:0003 'Program number
N010 G50 S1500; 'Set max chuck speed
N020 G96 M04 S200; 'Turn on constant surface speed, Start splindle clockwise @ 200M/Min chuck speed
N030 G99; 'Turn on feedrate mm\rev
N040 /M08; 'Option turn on coolant
N050 G00 X52.00 Z1.00; 'Rapid positioning, Move to position X52 if a bit bigger than the diameter of the stock work peice
N060 G71 P070 Q190 U0.5 W0.00 D1000 F0.25; '(G71)Z Profile,(P060)Start of facing cycle,(Q070)End of facing cycle,(U0.5)Finishing allowance X directing.(W0.25)Finishing allowance Z directing,(D500)Depth of cut 0.5mm.
N070 G00 X31.00 Z0 ; 'Start of tit on the end ---------Errors here-------------
N074 G01 Z0.00;
N075 X31.75 Z-0.5; 'Tit in the end
N080 X37.00; 'Start of taper
N090 X40.45 Z-5.70; 'Cut taper
N100 Z-17.10; 'Thread leadin start
N110 X45.00 Z-19.38; 'Thread lead in
N120 Z-28.25; 'Thread length
N130 X41.50 Z-30.00; 'Thread lead out taper
N140 Z-33.40; 'Tharead Clearence
N150 X49.30; 'Start of taper
N160 X50.8 Z-34.10; 'Cut taper
N170 Z-39.25; 'Head flange length
N180 X49.3 Z-40.00; 'Cut taper
N190 Z-45.00; 'Clearence cut
'finishing
N200 G70 P070 Q190 F0.15; '(G70) Finishing cycle,(P060)Start of facing cycle,(Q070)End of facing cycle
N210 /M09; 'Option turn off coolant
N220 M99; ' Return from sub program
As expected the code runs if i leave out the Z0.00 but the pocket is missed out on the roughing cycle but is done on the G70 finishing
Then manual says it can do it but there is no examples. I've had a Google and the examples i find have the same issue
What am i missing
Cheers
