586,956 active members*
3,064 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > Lathe stops mid program, no alarm
    Dec 2006
    447
    My CAM software seems to be outputting something the Haas does not like. The lather will run through the program in simulation mode but stops at the line with the arrows after stating the cycle. It does not throw an alarm, it simple stops everything but the spindle. I'm hoping someone can see the problem because I've tried everything I can imagine with no joy.
    N180 (MICRO GROOVING .0165 R)
    N190 T0202
    N200 G54
    N210 G98 G97 F0.001 S1200
    N220 M03
    N230 /M08
    N240 G18
    N250 G00 Z0.1 X2.68
    N260 X2.603
    N270 Z-0.3898
    N280 G01 X2.6807 F0.001 <<<<<<<<<<<<<<<<<<<<<<<<<<<<<
    N290 G02 Z-0.3504 X2.6893 R2.1135
    N300 G03 Z-0.2965 X2.61 R0.0565
    N310 G01 Z-0.2615 X2.61
    N320 G00 X2.603
    N330 Z-0.3909
    N340 G01 X2.7006
    N350 G02 Z-0.3426 X2.7109 R2.1235
    N360 G03 Z-0.2965 X2.63 R0.0465
    N370 G01 Z-0.2615 X2.63
    N380 G00 X2.603
    N390 G01 X2.65
    N400 Z-0.2965
    N410 G02 Z-0.333 X2.723 R0.0365
    N420 G01 Z-0.333 X2.7257
    N430 G03 Z-0.3365 X2.7321 R0.0035
    N440 G00 Z-0.3365 X2.603
    N450 Z-0.3921
    N460 G01 X2.7205
    N470 G02 Z-0.3368 X2.7321 R2.1335
    N480 Z-0.3365 X2.7321 R0.0035
    N490 G00 Z-0.3365 X2.603
    N500 Z-0.3898
    N510 Z0.1
    N520 X2.68
    N530 M09
    927
    Feed rate is Inchs per minute?? That would be .001 inches per minute..you would be there a long time..
    Dec 2006
    447
    WMS has saved my bacon again .001 inches per minute takes a long time to get anywhere.
    Feb 2007
    381
    This line calls G98. G98 is inches per minute. Change to G99 if you want to use inches per revolution.
    Mike
  1. VMC40 Program Stops
    By rdoty in forum Fadal
    Last Post: 12-01-2010, 02:59 AM
  2. spotdrill program stops for no reason?
    By rob jerico in forum Fadal
    Last Post: 10-15-2010, 05:58 PM
  3. Fadal 4020 stops at line 13 or 16 in program
    By ThatguyDave in forum Fadal
    Last Post: 09-09-2009, 08:57 PM
  4. VF-2 stops in the middle of a program!!
    By southernexplore in forum Haas Mills
    Last Post: 08-12-2009, 06:34 PM
  5. Lathe program/alarm issue
    By kperk12345 in forum Okuma
    Last Post: 10-11-2007, 07:57 AM
