586,320 active members*
4,083 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > 2.2KW 220v Chinese spindle on 208v 3ph?
Results 1 to 7 of 7
    Nov 2008
    522
    I have a 2.2KW Chinese spindle, and a Hitachi X200 VFD. That VFD can take single-phase or 3-phase over a wide voltage range.
    I might install it in a location where there'd be 208v, 3-phase. I don't think there's 220v single-phase available. But 208v is a lower net voltage, I didn't think about that.
    The VFD will run ok, I don't have a question there. But will the spindle have enough voltage to actually reach its maximum rated speed with a 208v 3-ph source?
    398
    Speed is related to the frequency of the drive. That should not be a problem,
    Not sure if you will have the maximum power (torque) available. Other issue might be with higher currents that might be required overheating might be n issue.
    But then again I know little about motors, understand basic physics.
    Dave
    You'll be better off with. 3 phase input. The power of the spindle is derated when you use the Vfd with single phase input.
    Jon
    Jul 2007
    1602
    It will work fine, as Dave mentioned the frequency controls the speed. In fact it is preferable to hook it up to 3PH if it is available.
    A VFD essentially converts to DC then converts back to AC at the set frequency. As long as the VFD is properly rated for your motor, it will be fine. A lot of people use the Hitachi VFDs with their Chinese spindles.
    bob
    Nov 2008
    522
    Quote Originally Posted by dfmiller View Post
    Dave
    Not exactly. Brushless motors do run at the frequency of the drive, as long as there is enough voltage. All brushless motors act as brushless generators, creating a Back EMF voltage simply because they're turning, and the BEMF voltage is proportional to speed.
    At some speed, the BEMF is equal to the supply voltage of the drive, and the motor will not be able to go faster. If the drive were to simply increase the frequency slowly, torque would drop to zero and it would slip out of sync and stall.
    Same reason a DC motor goes slower at reduced voltages, really.
    24221
    The difference between 220 1ph and 208 3ph is probably marginal, as the 3ph supply to the motor is reconstituted from a DC source, the 3ph peak DC would be around 294vdc and the 1 ph 220 would be around 310vdc, BUT the DC derived from three phase has far less ripple than the rectified 1ph, where the ripple is =100% before filtering.
    The DC derived from 3ph is far more efficient for the same voltage due to the very small comparative ripple than that of 1ph.
    While we are talking VFD's the standard induction motor can never reach synchronism as mentioned, increase the frequency and the motor will increase rpm, but always at around 4~7 cycles below applied frequency.
    Al.
    398
    Quote Originally Posted by MechanoMan View Post
    The OP is talking about a 3 phase AC motor.
    Dave
  1. Mini Mill X2 Spindle Head + VFD + Chinese Spindle= custom!
    By diyengineer in forum Uncategorised MetalWorking Machines
    Last Post: 12-26-2016, 10:04 PM
  2. chinese 220v help
    By bpoulin in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-25-2011, 10:17 PM
  3. 220V/208V?
    By vpmachine in forum Uncategorised MetalWorking Machines
    Last Post: 01-28-2011, 07:54 AM
  4. Speed control for a 110VAC spindle motor in 220V enviroment
    By ftec in forum CNC Machine Related Electronics
    Last Post: 06-17-2008, 05:16 PM
