586,414 active members*
3,398 visitors online*
    Jan 2010
    Surface Finish
    Hello,
    Got a question I have an old version of mastercam 9 and when I post out a program I can get a smooth finish it's breaking it up into lines giving me a checker board finish can't make it da anything else how do I fix this?
    Nov 2005
    196
    You'll need to include some more info to get a good answer.
    Material?
    Machine?
    Speed & feed?
    Depth of cut?
    Type of cutter?
    Jan 2010
    17-4,Hurco,6500,.005,.125 carbide ball nose
    Dec 2008
    3111
    Missed out the cutter size...
    What are your "Tolerance" settings in the operation
    OFF - will give point to point code & give a faceted appearance to a curved surface
    1:1 ( or one of the others ) - should give out a lot less code, a lot more arcs, & eliminate the faceted look
    the smaller the numbers the more accurate the path.....the less arcs, more point to point moves in the NC code, ... so you try find the happy number, to suit the part purpose, start around .0010"
  1. Surface Finish
    By pgf545 in forum PTC Pro/Manufacture
    Last Post: 01-24-2012, 04:03 PM
  2. Surface Finish
    By dlange in forum MetalWork Discussion
    Last Post: 09-21-2010, 07:02 PM
  3. Surface finish
    By skmetal7 in forum Mini Lathe
    Last Post: 09-10-2007, 06:56 PM
  4. surface finish
    By fadalman in forum BobCad-Cam
    Last Post: 03-03-2007, 08:30 AM
  5. 32 surface finish
    By mroy0404 in forum MetalWork Discussion
    Last Post: 05-29-2006, 03:02 AM
