587,006 active members*
3,136 visitors online*
    Feb 2009
    6028
    Backing up parameters
    So, i got our TM2 configured for the laser, got our old rotary table working and calibrated. I would like to back up all the parameters on to a USB stick. Anyone have an idea how to back up parameters on the USB? It's a 2011 TM2 Btw.
    Aug 2010
    579
    press LIST PROG
    select the USB
    (Optional file name)
    press F4
    select SAVE All-BACKUP
    press WRITE/ENTER
    Ken Foulks
    Feb 2009
    6028
    Thanks all!
    Will do it first thing in the AM.
    Nov 2010
    Glad I found this thread!! Thanks Ken.
    I just did a backup of the offsets on a 15 month or so old VF2SS. I opened it in cimco edit and all of the numbers are there. As far as loading these values back onto the machine when we re-run this job, what is the procedure? When I saved the file, I just called it 'offsets' and there is no .TXT or .NC or extension. What should I change the extension to to reload the offsets? I've checked the HAAS manual and it is sorely lacking in info :-(
    May 2004
    4519
    Quote Originally Posted by Black08Chally View Post
    This would be better put in a new thread of its own. Your subject is for offsets. The original post was for machine parameters.
    Aug 2010
    579
    Haas Factory Support
    Whether it's parameters or offsets, loading them back in is easy. When you select save all it saves multiple files with different file extensions. Here is an example list:
    VF-2.par
    VF-2.ofs
    VF-2.set
    VF-2.pgm
    VF-2.var
    If you want to reload just the offsets, follow this procedure:
    press LIST PROG
    select the USB
    Select the file
    press F4
    select LOAD OFFSETS
    press WRITE/ENTER
    Ken Foulks
  1. Backing Up Parameters? (OSP700L)
    By H234 in forum Okuma
    Last Post: 10-11-2020, 09:25 AM
  2. Backing Up Parameters on 10m & 6t
    By C-4 in forum Fanuc
    Last Post: 09-23-2011, 08:06 PM
  3. Replies: 2
    Last Post: 04-02-2011, 12:31 PM
  4. Backing up Parameters
    By wganders in forum Daewoo/Doosan
    Last Post: 01-07-2010, 08:18 PM
  5. backing up parameters
    By robinhood2b in forum Bridgeport / Hardinge Mills
    Last Post: 09-30-2009, 03:31 PM
