586,471 active members*
4,235 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > 3 phase transformer - on single phase?
    Apr 2005
    345
    I am retrofitting two Boss5 machines. Can a 3 phase transformer be used with single phase? Could I "chop" off the third leg coils?
    Scott
    24223
    Not really practical, is it 3phase out? What is it the transformer feeding? Often the low power control can easily be converted to run off 120 or 240 1ph and the high power is usually either spindle and pump motors and/or servo's. What is there presently on the machine that is three phase?
    Al.
    Apr 2005
    345
    The main transformer is 3ph in/out. I thought I could save a few bucks by reusing whatever possible from the machine. I am retrofitting with Gecko's/Mach3, and want to run the DC bus at ~50V. Theres a whole bunch of transformers in the machine, maybe I will just toss them.
    Scott
    24223
    If they are single phase transformers in the machine, I would check before tossing as they may come in usefull for other supplies.
    Al.
