586,535 active members*
3,108 visitors online*
Page 3 of 9 12345
Results 41 to 60 of 162
  1. #41
    Nov 2010
    216
    Picked up the frame from the powdercoaters today. Tonight im going to try to get the casters and compressor mounted on it and bring it home to my garage.
  2. #42
    Dec 2011
    161
    Pretty nice! I like the idea of the whole thing carrying the compressor and everything, if you need to move it just unplug from the outlet & run, nice
    Keep on it, i'm really looking forward to see the whole thing enclosed :P
  3. #43
    Nov 2010
    216
    ^ Troll.
    Got the frame home and with the help of a buddy lifted the machine onto it....Man was that heavy. Also slid the coolant tank into it and got the casters on. Starting to look like a machine! Next will be getting the head painted and mounted and the Z-mounts bolted on when they show up. My buddy is also going to start making the big ass stainless chip pan for this thing. This machine is turning out bigger than I imagined....but thats a good thing - im loving it!
  4. #44
    Nov 2010
    216
    This weekend my buddy bent up the 18 gauge stainless coolant pan for the frame.
    First we started with clamping the sides to the frame.
    This was after we got the bottom pan riveted to the sides. He also bent up a cover for the frame rails in front of the machine.
    Next we removed it and i drilled the side holes to mount it to the frame. The frame will have rivnuts installed to bolt the pan to
    Then I drilled a hole to mount the drain in the pan
    Finally, I installed some sound deadener on the bottom side of the pan to prevent rattle from any machining vibration.
    Tomorrow and the next day I'm hoping to seal the seams from the bottom and then install the rivnuts and get the pan bolted back in.
  5. #45
    Jun 2010
    1414
    wow... I really love that pan. Its absolutely perfect. You going to weld it? Love the lambo in the background. That frame is beastly. I like the idea of the compressor with it. Self contained is functional. What sort of coolant unit is that?
    Love the build all together!
  6. #46
    Nov 2008
    61
    I would suggest not putting a cover on the frame rails below your stepper motor, Coolant and such sill pool on it and make its way to the end coming out of the table. Any reason why it needs to be there, it would seem to me that it could just fall between the rails into the main pan.
  7. #47
    Jun 2004
    6618
    I think the pan there would serve a good purpose. As a work surface when you work on the mill or load fixtures. You don't want to load the mill and cycle start if you still have an errant tool sitting on the table, but one there wouldn't hurt anything.
    It would do double duty protecting the actual pan from dropped tools. As Murphy's Law indicates, a heavy sharp tool will land point first in something you don't want punctured. That goes for legs, feet, and coolant pans.
    Perhaps keep it removable and remove when hogging off big aluminum.
    Pan is looking great, BTW.
    That is on par with the rest of it. Excellent work on this.
    Lee
  8. #48
    Nov 2010
    216
    Nope no welding. We were going to weld it originally but figured it would be far less work to bend seperate sides and bottom pan and rivet it together. Very glad we went this way as the fit was TIGHT. Chances are the welded pan wouldn't have squeezed in. The coolant unit is one from machinetoolwarehouse. It's pretty basic and the quality isn't the nicest looking but functionally it should be fine.
    Quote Originally Posted by PHSS View Post
    The cover is actually bent with a spine down the middle so the coolant will run off in either direction Half inch slope either way. Also that won't really be the front edge of the machine because the upper enclosure (or rather the bottom of the door channel) will sit higher than that. There's no functional reason the cover has to be there, I just think it makes it look more finished.
    Tonight I got a couple things done. The main one was getting the pan sealed. I used automotive seam sealer (used it many times for automotive projects - works great). I also did some work on the control panel but no pics of that. Thanks for all the comments guys, it's nice to see people are watching the thread.
  9. #49
    Aug 2005
    158
    Quote Originally Posted by mikemaat View Post
    I have often wondered how much power coating costs. Would you care to share what you paid for the process?
  10. #50
    Jun 2010
    1414
    What kind of automotive seam sealer? Permatex?
  11. #51
    Nov 2010
    216
    No it's pretty generic stuff, I don't recall the brand. Comes from the body shop supply place in town though. The powdercoat cost me $250 but if you factor in the primer and paint and time it would have cost me if I had painted it then it doesn't seem as expensive. Not to mention, the paint would have gotten pretty beat up.
  12. #52
    Aug 2005
    158
    Thanks for letting me know the cost. As you say, not all that bad considering what you did not have to do.
  13. #53
    Mar 2011
    525
    Everything looks great!
    Kelly
    www.finescale360.com
  14. #54
    Nov 2010
    216
    Scott @ Benchtop sent me pics of my Z-axis mounts and Pulleys I designed. Cant wait to get them in!
  15. #55
    Aug 2005
    158
    I am planning a similar conversion. Can you tell me what belt you are planning on using? Tooth profile, pitch and width?
    Thanks again,
    Arvid
  16. #56
    Nov 2010
    216
    McMaster Carr #9003K28. I stole this part number from another thread and based my drawings on it. Im hoping it works...
  17. #57
    Aug 2005
    158
    Thanks again for the quick response.
  18. #58
    Nov 2010
    216
    Today I made it out to the shop to do some body work on the head. I started with the raw metal head, then primed it with self etching primer. Next I threaded bolts into all the unneeded holes, cut them off and staked them into the holes. Next I body filled over them as well as body worked any raw casting areas that weren't fly cut. Finally I reprinted again. I have a few more areas I have to body work further.
  19. #59
    Jun 2010
    1414
    Its going to be too pretty for you to want to use it
  20. #60
    Nov 2010
    216
    Haha thats what im afraid of..
Page 3 of 9 12345
  1. Full Enclosure and Coolant System Upgrade
    By anglin in forum Tormach Personal CNC Mill
    Last Post: 05-01-2014, 04:43 AM
  2. What RF45 clone should I get?
    By Nigel Tufnel in forum Benchtop Machines
    Last Post: 12-03-2013, 06:24 AM
  3. new linear way mini millw/full atc, coolant, enclosure etc.
    By fixridermtl in forum Vertical Mill, Lathe Project Log
    Last Post: 06-18-2013, 05:48 PM
  4. Tool Room Lathe - full enclosure or not?
    By flashno in forum Haas Lathes
    Last Post: 10-16-2008, 08:38 PM
  5. Pics of my RF45 clone cnc conversion with flood coolant
    By CNCPlastic in forum Knee Vertical Mills
    Last Post: 01-26-2005, 09:02 PM
