586,362 active members*
3,385 visitors online*
Results 1 to 20 of 36
    Sep 2007
    133
    Ridgid tapping on Fanuc
    Hi, I got Miyano BND 51s5 with Fanuc 21i-T controler
    been keen to do ridgid tapping
    I performed the command
    G97 s1000 M3
    G84 z-10 F2.
    G80
    G0 x100.0 z100.0
    and wha happend is acually the tool went right in M3 and right out with M4
    but what was missing is that when the tool reached to z-10 the sppindle took a long time to stop thus breaking the tool and didnt syncronize the feed with the spindle speed usually with proper ridgid tapping it should slow down when it starts reaching the z-10 then turn to M4 but what happend is the tool reached to z-10 first then the spinde stoped after reaching to z-10 ...is that paramerts problem? or its simple missing hardware piece on board?
    i tried to put M39 (the 2200 parameter is set to 39, so I tried using
    M39 s1000
    g84 z-10.
    etc..
    but the spindle refuses to turn on M39 command..
    anyone can help?
    Aug 2011
    2517
    Parameter 2200 is not relating to Rigid Tapping.
    Generally to set Rigid Tapping Mode you should put an M29 S*** before the G84
    M29 S1000
    G84 Z-10 F2.
    G80
    G0 X100.0 Z100.0
    From the manual.....
    The M code used to specify rigid tapping mode is usually set in parameter
    No. 5210. The M code is judged to be 29 (M29) when "0" is set.
    To use an M code whose number is greater than 255, Specify the code
    number with parameter No. 5212.
    2932
    Per the 21iT-A and 21iT-B Parameter Manuals:
    If prm 5200 bit 0 = 0, then the M-code for Rigid Tapping is set in prm 5210. If 5200 bit 0 = 1 then Rigid Tapping mode is not set by M-code.
    Sep 2007
    133
    thank you for your reply
    I have 2 main coolants on M08 and M28 for turning on and M09 and M29 to turn it off..
    so how can i use M29 to turn the spindle on when its for coolant?
    My 5210 says 39...
    so i assume M39 s1000? if so the spindle doesnt turn on M39 command..
    and 5200 bit 7 is set to 1, i can set it to zero if i wish but M39 doesnt turn the spindle on it just sits there dong nothing...
    Sep 2010
    1230
    Quote Originally Posted by peaceandcalm View Post
    My 5210 says 39...
    If you're testing your program in single block, the block containing the synchronize code (M39 in your case) does not start the spindle. In all cases of rigid tapping I've seen, the spindle starts when the G84 block is executed and stops upon its return to the R level after completing the tapping operation on the current hole.
    Are you confusing bit 0 and bit 7 of #5200, or are you just making the observation that bit 7 is set to 1.
    Bill
    Sep 2007
    133
    Quote Originally Posted by angelw View Post
    Bill
    hi, first i tried without single block still the spindle wont turn on M39 command
    and as far as i know Bit 0 is on the far right like this?
    #7 #6 #5 #4 #3 #2 #1 #0
    so in this case bit 7 on mahcine default is set to 1
    i can change that to 0 ofcourse but what would that do?
    all i know if i put that to zero then i have to use M39 if i leave it to 1 then i dont have to use M39 s1000 is that correct?
    in anycase regardless if that is set to 1 or 0 spindle wont more on M39 command..
    24222
    Not sure about the i series, but do you have an encoder on the final spindle shaft?
    Al.
    Sep 2007
    133
    what is encoder?
    Sep 2010
    1230
    Yes you're reading it correctly, bit 0 is the right most bit in the byte. However, its bit 0 of #5200, not bit 7, that determines if an M code is used for rigid tapping, and should be set to 0 if the M code defined in #5210 is to be used.
    Bill
    24222
    Feedback device to synchronize the Z with the spindle revolutions.
    The earlier Fanuc also required an option parameter for rigid tapping.
    Al.
    Sep 2007
    133
    yes bit 0 is set to 0
    and i am not sure if i have this feedback device on main spindle, how can you tell?
    My G84 works perfect except for that suncro problem, so by the sound of it i might not have that device installed? is that a chip on board? or accual hardware?
    24222
    Most lathes DO have an encoder, you need it for CSF and Feed/rev.
    But I know the older Fanuc's required the option parameter for rigid tapping.
    Al.
    Sep 2007
    133
    when you talking about an encoder, is software? or a chip hardware?
    can i edit any paramerts to fix this? i do have all the usuall parameters from 5200 all the way down but somehow they all set to zero..except 5210 which is 39...
    24222
    It is a hardware item, but I would be surprised if you did not have on that make of lathe.
    http://www.google.ca/search?q=rotary...w=1481&bih=938
    The option parameters are accessible by password on the i series, these are 9000 series options which Fanuc charge for.
    (PM sent)
    Al.
    1792
    Quote Originally Posted by dcoupar View Post
    and G84/G88 would always work in rigid mode, provided rigid-tapping option is available.
    Aug 2010
    156
    ok here is something to think about. this is a lathe. Most Lathes do NOT have rigid tapping on main or sub spindles. most are belt driven. not knowing if you have a 3 jaw, 4 jaw, collet nose or face plate. how does a machine builder know what kind of acceration/deceleration needed based on the weight of your part and how your holding it to stop a slippery belt in time to reverse. if you get it right once it wont be the same on the next part.
    get yourself a floating holdder and use it.
    If it is a live tool then dont forget about Plane selection G17-(z axis depth of hole) G18-(y axis depth) G19-(x axis depth)
    Without proper plane selection the tap will just sit at the R-plane waiting forever
    (almost always without alarms)
    IF you really want to continue on the main or sub spindle you still have to change to G17 so it can drill along the Z axis. a lathe is defaulted to G18
    Good luck
    Sep 2007
    133
    i know i use floating holders there is no way around it...
    thanks all for your help.
    Aug 2011
    2517
    the key is the option. rigid tapping is an option. if you don't have it then you can't do rigid tapping.
    Feb 2009
    6028
    Agree with hitachiboss. Most lathes won't rigid tap unless they have live tooling.
    Jul 2008
    27
    you should change parameter #911
  1. DS30SSY Ridgid tapping cycle
    By cgmr53 in forum Haas Lathes
    Last Post: 06-27-2012, 11:53 PM
  2. Ridgid Tapping 1/4-20
    By southernexplore in forum Haas Mills
    Last Post: 10-16-2009, 08:45 AM
  3. G84 (ridgid tapping) on Mitsu 50L controller
    By Chuck Reamer in forum G-Code Programing
    Last Post: 02-19-2008, 04:00 PM
  4. Ridgid Tapping on Haas
    By Shotout in forum Haas Mills
    Last Post: 08-02-2006, 03:40 AM
  5. ridgid tapping with servos
    By miljnor in forum Servo Motors / Drives
    Last Post: 09-21-2005, 07:35 PM
