If i am maching one part which offset table should i be useing? Pallet offset fixture offset or nc offset?. And how do i add multi parts if i need to? And which page do i put my tool lenghts in active tool set or tool file?
Thanks Dave,
Thanks Dave,
There is a copy of the operators manual here:
http://websystem.gismo.se/gismo/file...G%20MANUAL.pdf
Check out chapter 4, there are some good step by steps in there to help you with you part/tool setups. At the end there is a "How Do I...." section for specific examples of some things.
Thanks laka i will read it
