586,655 active members*
2,342 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Toolpath for screw extruder on a lathe
Results 1 to 11 of 11
    Oct 2011
    Can anyone help me on defining a toolpath on mastercam lathe (no live tooling) to create a screw extruder from an imported parasolid file from SolidWorks?
    I tried to rough chain it with solids, but it gives me an error "unable to extract lathe profile from solid".
    Here's a picture of what it looks like: http://www.robertbarr.com/images/innovation.jpg
    Is it also maybe possible to custom create this with the thread toolpath on the lathe?
    Dec 2006
    116
    Try on a new level : create surfaces from solid then use the surfaces to create a turn profile then use that profile to chain the tool paths
    WANNA GO FASTER
    Oct 2011
    Hi metlshpr, thanks for the advice.
    I tried creating surfaces and then a turn profile like you said, but all it did was give me a square box as my profile. Which means I am only roughing down the diameter of my stock.
    Do you have any other thoughts?
    Dec 2006
    116
    I think you should try to go the "thread" tool path way. Because of the "screw pitch" of the part MC is having trouble profiling. It is seeing the pitch when it turns the model as high points and creating a profile as such. You should be able to figure out the "pitch" of the screw and then use different z offsets to remove the bulk of material. I'm not sure how big the the part is, hard to tell from the pic, so you might just need a special or profile tool then just "thread" the part. If you want, post a file and I'll take a look.
    P.S. I'm using X5
    WANNA GO FASTER
    Oct 2011
    Here's the parasolid file of one of the screw segments.
    Attached Files Attached Files
    Dec 2006
    116
    I'm not sure what your resources are but I would grind or EDM a form tool and program this as a thread. You should be able to get the angle and the .02 rad from the "insert" of the tool.
    WANNA GO FASTER
    Oct 2011
    Thanks for the help!
    I guess I'll try grinding a form tool for this part then.
    Dec 2006
    30
    haaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
    sorry this is funny
    first of all the pitch on a extruder is ususally from 4 to 8 inches per turn
    and sorry this is funny
    Dec 2006
    116
    Quote Originally Posted by jamfixer View Post
    sorry this is funny
    Sorry but I don't see what the pitch size matters to the cnc. It will do what ever you tell it to do. Maybe you should look before you leap (speak). The pitch on this particular part is around .750. By the way this forum is for sharing and getting knowledge, not for stroking people with superiority complexes. Thank you and have a nice day. (flame2)
    WANNA GO FASTER
    Dec 2006
    30
    i man know u sould stop trying to steal de idea from the peoplw whom employ u and unlike u i man know jesus and mohamad and ihazia fer de jews ,,u still a likkle boy with a *****
    Dec 2006
    116
    Here it is.:banana:
    WANNA GO FASTER
  1. Need help with Lathe Contour toolpath, please.
    By awolfoutwest in forum GibbsCAM
    Last Post: 11-23-2011, 05:23 AM
  2. Homemade Aluminium Extruder
    By Russo08 in forum MetalWork Discussion
    Last Post: 11-23-2011, 05:20 AM
  3. Want to build my first mill / extruder combo
    By r00tb33r in forum Maintenance DIY Discussion
    Last Post: 06-15-2011, 02:39 PM
  4. lathe point toolpath
    By camtd in forum Mastercam
    Last Post: 04-12-2009, 11:57 PM
  5. changing mill pocket toolpath to lathe-v9
    By scolee in forum Mastercam
    Last Post: 03-25-2007, 03:39 PM
