586,399 active members*
3,142 visitors online*
Results 1 to 8 of 8
    Jun 2009
    14
    G72.1, G72.2 doesn't work!
    Hi all,
    I try to drill in the same PCD by the equal degree. I used main and subprogram.
    Main
    G92 G17 X100. Y100.;
    G72.1 P4000 L24 X0 Y0 R15.;
    G80 G0 X100. Y100.;
    M30;
    Sub
    O4000 G90 G81 X0 Y98. R5. Z10. F100;
    M99
    But the alarm show inproper G CODE at G72.1 Anybody can guide?
    OKK/ Fanuc 18M/ Vertical Machining Center
    Cheer!
    Sep 2010
    1230
    Quote Originally Posted by Maxz View Post
    Hi all,
    Main
    G80 G0 X100. Y100.;
    M30;
    Sub
    M99
    Cheer!
    Figure Copy G72.1 and G72.2 are optional functions, and given that you're getting an Improper G Code alarm, you're control does not have these functions.
    Bill
    Jun 2009
    14
    Thank you Bill,
    So what should I do for operating this multiple holes?
    Normally, I use CAD/CAM program for this type of job. Anyways, it should have other simply method to operate in front of machine. Some time machine operator doesn't wanna wait for CAM programmer to generate this basic job.
    Best regards,
    Maxz
    Sep 2010
    1230
    Thank you Bill,
    Best regards,
    Maxz
    Hi Maxz,
    Your control is likely to have User Macro B, which is a pseudo Basic type language. Its quite a powerful programming tool limited in many way only by your imagination. I'm not sure about their current system, but Fanuc's early Conversational Program was entirely based on their User Macro executable, including the input prompt pages.
    Using this feature, you could write simple Macro programs that can be accessed at the control to do simple things like holes on PCD etc.
    Bill
    Sep 2011
    68
    Also your R (retract plane) value is less than the Z (hole bottom) value in the G81 line... Even if you had a machine with G72.1, this would cause an error.
    Jun 2009
    14
    Thank you Texaspyro, this is a little thing that i am always miss it.
    Bill, I am quite poor in G-code. I started working by CAM program. So I have no any knowledge about Macro. I started with wrong fundamental basic. Some time I just think that Fanuc control should be able to help me more than receive data and run moving.
    Thanks again.
    Sep 2010
    1230
    Thanks again.
    Maxz,
    Send me your email address via Private Message, along with a list of the sort of things you would like to be able program at the machine, and I'll see what I have that will be of help to you.
    Bill
    Sep 2011
    68
    Like all things Fanuc, they probably have a very expensive option available for doing that... I've always wanted the WIWIWIG option (What I Want Is What I Get)
  1. Work Planes / Work Coordinates
    By MICFDI in forum Esprit
    Last Post: 10-04-2014, 02:41 PM
  2. Work holding options to hold thin round work? .024, .046 etc
    By KyleH2 in forum MetalWork Discussion
    Last Post: 06-07-2010, 07:22 PM
  3. Some of our work.
    By TAJS in forum Machine Created Art
    Last Post: 04-01-2008, 04:42 AM
  4. Anybody needs work done on VMC ?
    By ajinkya.rao in forum Uncategorised MetalWorking Machines
    Last Post: 02-18-2007, 05:31 PM
  5. art work
    By tmt_92021 in forum Mastercam
    Last Post: 08-19-2006, 01:21 PM
