We have this machine , It's a Fadal right?
MAKE SURE you are using G43 for all your "H" value call outs.
M6T1
G43 H1 Z1.
The machine also gets hot in the panel, Clean your fan in the back, your Z card may be getting ready to fail.
I lost low range and was using .2 for high range for a long time before I got a new card.
Offset E30 and H90 are used for O9998 , and make sure no one changed HOME Z while you were away.
It's really good just to call the tech at fadal.
you could call G10 to check for Z height; until you find the issue.
and compare value of the Machine ABS Z against the value of the height of the top of your stock.
This would tell you if your going to crash the machine.
or if it still crashes.
Notice I said if your going to crash.
Then it's the card.
G10 has a "L" number and for the life of me I can't find it again.
please don't Quote me.
say the "L" letter is 13 , to my recollection or knowledge. :
( USAGE AS A SUB NOT GOING TO WRITE IT ALL YOU MUST ADD)
#R3=0
#R2=0
G10 L13 P0
#V1=R3
#IF H0 NE 0 THEN GOTO :CRASH
G10 L13 P1
#V2=R3
#R2=0
#IF V1 GT V2 THEN GOTO :CRASH
GOTO :START
#:CRASH
M0 ( YOUR GOING TO CRASH )
M5 M9
#:START
START
I CAN'T TELL IF THAT'S RIGHT
the fadal manual might get you started.
http://www.fadalcnc.com/Tech_files/U..._1_Summary.pdf
off to play poker on facebook.
