I recently purchased a CNC kit off of ebay, it should be delivered tomorrow sometime. I was wondering if anyone see's anything missing (not counting the lathe, box to wire them in etc) in this kit to make a 2 axis CNC lathe. I dont see any "driver boards" like Keling has. But just let me know, and sorry if this is the wrong thread.
eBay - New & used electronics, cars, apparel, collectibles, sporting goods & more at low prices
That is the link to ebay.
This Item includes:
3 PCS Nema 23 Stepper Motors with 287oz-in holding torque,
1PC 200W,24VDC power Supply,
1 PC 3 Axis Driver Board & 1 Cable,
1 PC Cable
Stepper motor|Stepping gearmotor wholesale|Stepping motor supplier
1, Stepper Motor
Technical Specifications
Part No.: 57BYGH603
Frame Size: NEMA23
Step Angle: 1.8 degree
Voltage: 8.6V
Current: 1.0 A/phase
Resistance: 8.6Ohm/phase
Inductance: 18mH/phase
Holding torque: 14.5Kg-cm 287oz-in (For Bipolar connecting, the holding torque is 287oz-in)
Rotor inertia: 480 g-cm2
Detent torque: 0.68 kg-cm
Number of wire leads: 6
Weight: 2.20lb (1.0 kg)
Length: 78mm
2, 3 Axis Driver Board
Products Features :
1:The maximum 3.5A drive current to a maximum 86 stepper motor drives, more powerful
2:1-16 sub-setting, higher accuracy, smoother operation
3:Overload over-current over-temperature protection, full protection of your computer and peripheral equipment
4:4 files current settings can be set according to the user the actual current requirement
5:Full closed-type optical isolation to protect the user's computer and equipment
6:Professional design, two-stage signal processing, super anti-jamming
7: Bipolar constant current chopper drive motor low-speed non-creeping phenomenon, noise, non-resonant region。
8: 2-way output control, scalable fifth axis or 2-way control of external equipment.
9: Four input control, you can set limit, emergency stop, which is divided into pairs of knives.
Please note the following before the test items
1, To determine the size of the supply voltage and current
2, Determine the stepper motor power and current (model)
3, Determine the stepper motor wiring
4, Power Please take 12 ~ 36V 8A (stepper motor in accordance with the work of current matching) The above switching power supply, I received a map indicating the power input interface。
12V power output for a 12V cooling fan to pick up where。
The definition of 1-PIN 25 of Parallel Interface is described as follows:
PIN9
PIN14
PIN7
PIN1
PIN2
PIN3
PIN8
PIN6
PIN4
PIN5
PIN16
PIN17
spindle motor
X
Empower
X
Dir
X
Step
Y
Empower
Y
Dir
Y
Step
Z
Empower
Z
Dir
Z
Step
Expand output 1
Expand output2
The definition of 1-PIN15 of Manual Interface is described as follow(Click the image to upper right for the P1 left P15)
P1
P2
P3
P4
P5
P6
P7
P8
P9
P10
P11
P12
P13
P14
P15
X Step
X Empowe
spind
X Dir
Y Empowe
Z Dir
Z Step
Z Empowe
Y
Limit
Z
Limit
Y
Dir
Y
Step
STOP
GND
5v/VDD
Limit Switch Description
Input 1
Input 2
Input 3
Input 4
Corresponding parallel P10
Corresponding parallel P11
Corresponding parallel P12
Corresponding parallel P13
Output Interface Definition:
P1
P2
P3
P4
P5
P6
P7
P8
P9
P10
P11
P12
P13
P14
P15
P16
P17
VDD
GND
XA+
XA-
XB+
XB-
YA+
YA-
YB+
YB-
ZA+
ZA-
ZB+
ZB-
MO/V+
GND
MO
