Looking for a suggestion. I use a G540 and output 6 is a constant problem.
Works for about a year then it has to go back for repairs.
I would like to find a different way to control my solenoids other than the G540.
I have a second parallel port that I can use to trigger the solenoids but I need something to trigger them.
As seen in the wiring diagram they currently use a 12v power supply that I can isolate from the G540. I can hook into LPT2 and disconnect output 6 from the G540.
Just need to know what board I can use.
TIA
dan
