[IMG][/IMG]:devious:
It can engrave acrylic, plastic, double-color board, wood, stamps etc non-metal materials and cut paper and very thin non-metal materials.
Specifications
Model: SCU4030
Working Area: (15.74x11.81in.)400x300mm
Table Size: (31.50x20.47 in.)800x520mm
Dimensions(LxWxH): (31.50x20.47x11.42 in.)800x520x290mm
Laser Source: Sealed CO2 Laser
Drive: Step Motor
Power: CO2 40W
Controlling system: USB
Throughput: 166.3 in²/hr(1072.8cm²/hr)
Transmission Way: Belt Transmission
Software: DSP
Speed Control: Adjustable from 0~100% of 42 IPS(up to speed settings per job)
Power Control: Adjustable from 0~100%(up to 16 color-linked power settings per job)
Support format: PLT, BMP, DXF, T100, etc
Resolution(DPI): 200,300,400,500,600,1000
Computer Interface: Standard Printer Port and USB Port
Process Material: Non-metal Materials
Engrave speed: ≤1000mm/s
Repeated accuracy: ≤±0.025mm
Cooling ways: Circulation of Water Cooling
Engrave depth: ≤1.2mm
Working temperature: 0-35℃
Working humidity: 5-95%
Working Power: 220V/50Hz/1kVA(As customized)
Net Weight: 40kg
Safety: Class IIIR Red Light Indication, Cap Protection, Huff Protection, Hydraulic Pressure Protection
Standard Features
Auto Focus:V
Red Dot Point:V
Channel Type Feed:V
Honey-comb Table:V
Full Formats Support:V
Power Consumption:280W
Quotation:USD2600 FOB Shanghai or Guangzhou
Kofi
[email protected]
