Originally Posted by
Jerry888
The THB6064AH is a PWM chopper-type sinusoidal micro-step bipolar stepping motor driver IC.
It supports 8 kind of excitation modes and forward/reverse mode and is capable of low-vibration, high-performance drive of 2-phase bipolar type stepping motors using only a clock signal.
Features
Single-chip bipolar sinusoidal micro-step stepping motor driver
Uses high withstand voltage BICD process
Forward and reverse rotation control available
Selectable phase drive (1/2, 1/8, 1/10, 1/16, 1/20, 1/32, 1/40, 1/64 step)
Output monitor pins (DOWN / ALERT)
Equipped with reset and enable pins
Built-in thermal shutdown(TSD) and over-current detection(ISD) circuit
Parameter
High output withstand voltage: VDSS 50 V
High output current: Iout 4.5 A (peak)
Packages: HZIP25-P-1.27
Dementions:3.6*1.4*0.5 cm
Weight:9.86g
Website:[url=http://www.hhbytech.com/en/]
dear jerry,
congrats for such a good product. I think you should put some units of it on the ebay. I bet it is going to be a perfect replacement for stk series drivers( i think they are uni-polar). As you said it has built-in thermal and o-current protection, it will be a long life solution for the diy'rs.
Why don't you make a successfull stepper driver with that and put the complete schematic here. It is going to make a perfect driver for nema 23 size motors.
jasminder singh
It is better to die for something than to live for nothing.
