587,008 active members*
3,382 visitors online*
Page 1 of 5 123
Results 1 to 20 of 97
    Aug 2011
    92
    New Mori owner, few questions
    I just bought my first VMC, pretty excited about it.
    I got a Mori MV-40B at auction, its a fanuc machine.
    I received some technical doc's with it but I am not sure if I am missing any books,
    It has
    Mori Seiki Electrical circuit diagram
    Mori Fanuc programming manual 10MA
    FANUC 10/11/12/100/110/120 Maintenance manual
    FANUC 10/11/12/100/110/120 Operators manual
    FANUC 10/11/12/100/110/120M - Modeal A Operators manual
    Am I missing any? Doesn't seem like there is much Mechanically about the machine, just info on programming and wiring.
    I am trying to figure out if its CAT40 or BT-40
    Anyone have any clues?
    thanks!
    Feb 2009
    6028
    damn computer................
    Feb 2009
    6028
    Mori Ladder Diagram
    Parts list
    Mori operation manual (not really needed)
    Take a picture of the ATC claw. Post back. Thats the only way you can tell, Mori spindles accept either without modification.
    Aug 2011
    92
    Well, as i was taking some shots and I found the ceramic on the taper is cracked
    Can you see what type of tool holder this uses from the pics?
    For the ceramic, is there any place that can fit a new ceramic insert? What are my options?
    Thanks!
    Attached Thumbnails Attached Thumbnails toolchangerclaw1.jpg   toolchangerclaw2.jpg   brokenceramicspindle.jpg
    Feb 2009
    6028
    Cat 40
    I have used GTI spindles to replace the taper. They put steel inserts in, but not sure they can do it without removing the spindle bearings. Last one, full rebuild with a new insert was ~7K. Mori used that ceramic for a few years only, while it held up fine in normal use, once something bad happened you got that. Could be ATC arm is out of alignment, spindle was crashed, or??
    That spindle is not to bad to get out, once you've done a couple. It's not a simple unbolt and drop however. I used to get one out in about 3 hours max.
    Aug 2011
    92
    Quote Originally Posted by underthetire View Post
    Cat 40
    I got this mill at an auction and don't have much history on it. I dont even have power run to it yet. So I am not quite sure if it was crashed or the ATC, I dont have tooling yet either... Was trying to figure out the BT versus CAT. From what you say sounds like I have cat.
    Based on the coolant and chips in the machine when I got it. It seems like it had been running fairly recently... I wonder when the cracking happened (not that it matters now)
    I am guessing its not easy to just get a new ceramic insert for this spindle, that would make things nice huh?
    Is the ceramic better then a steel insert. Seems like the hardsurface wouldn't wear at all (which is great) but if its crashed something that might wear the taper a bit cracks this one.
    So, 7k for a spindle rebuild. Wow that sucks, it will definitely delay me getting this machine running for a while.
    Feb 2009
    6028
    Oh, its CT for sure. I prefer the steel inserts. If they wear you can have them re-ground on the machine. If you want my opinion, get some either cheap or used CT40 holders with the correct retention knob, and run it. Dont push too hard, or expect 0 run out. See if the rest of the machine is ok, that will also give you time to evaluate the spindle. Unless there is a vertical crack all the way up the insert, it will be ok for a while. At the time you decide to repair it, get a good tech in to pull the spindle that has done them before, and make sure he has a drawbar dynamometer to test tool clamp force.
    Aug 2011
    92
    hmmm, so your thinking I can probably get away with running and cutting with the cracked taper? It seems like all the damage is at the bottom. Nothing I am planning on doing so far is super critcal with tolerancing (+/- .003") so a little run out is ok with me as long as i can get decent surface finish.
    Feb 2009
    6028
    Ive seen them worse and still running.
    BTW, dont forget, a VMC such as that require level and tramming upon instalation. You dont want to get it wrong, as those coolant tanks are a PIA to get back out, and almost impossible when full of coolant.
    Aug 2011
    92
    I am going to be leveling it in the next day or two. What do you mean by Tramming?
    Sorry, I am very new to the world of VMC's
    Feb 2009
    6028
    [ame=http://www.youtube.com/watch?v=YHZGhPkdH8A]how to tram a mill ut.wmv - YouTube[/ame]
    This is obviously a bridgeport style manual machine, but the basic concept is the same. Mag base on the spindle, indicator swing as much as you can fit on the table. Gauge block. Adjustment is made by the leveling pads. Spindle has to be square to the table, level isn't as important, but you should not use a carpenters level, I use a .0002" per 10" level for this. Couldn't find anything on youtube for bed mills, maybe I could be a star..not.
    Tolerance is no more than .0005 on a 15" circle for a used machine IMO. Closer is better.
    Aug 2011
    92
    Do you have any clue if the spindles throughout the production range will interchange on the MV-40B?
    I found someone with a rebuilt spindle from a machine in the 92-94 vintage.
    My machine is a 88
    Part number on replacement spindle is 166101203
    Feb 2009
    6028
    Not sure on the part number, doesn't look like a valid part number to me. No way for me to be able to tell you for sure. The mv40 spindles were integral even back then I believe. 90-92 would be for sure. So the rotor diameter would have to be the same as well as the spindle housing diameter length, cooling grooves, etc. I honestly don't think they would be since mori changed the whole drawbar type in those years, but again, without having them side by side I couldn't tell you ya or na.
    Aug 2011
    92
    Does unit 522F mean anything?
    Feb 2009
    6028
    I have no way to check part numbers any longer since I took a cushy job. Usually they had a letter followed by a 6-10 digit number. I'd try calling your local rep and ask for a written quote. They put part numbers on the quotes...
    Aug 2011
    92
    kind of like
    WO7165A
    WO7145A,
    I will do some more digging. thanks again
    Sep 2009
    68
    Hey blkaplan
    I read that you have "Mori Seiki Electrical circuit diagram", I have a Mori Seiki MV40 but beside the maintenance manual and operating manual I didn't receive any other documentation with the machine so I was wondering if you are willing to share with me?
    all i have to offer is mu operating manual and the 2 years experiance that i have with this machine
    Aug 2011
    92
    Cat 40
    I just got off the phone with Mori and they said the machine was listed as a BT machine, are you sure that it has a CT arm on it?
    I also asked about replacing the ceramic taper and they said that the insert can not be replaced but a new shaft has to be installed with the ceramic built in.
    Sep 2009
    68
    it is definitely CAT I have the same arm on my machine.
    the taper on my machine also has some small cracks but it runs just fine so try it first like it is, and then if it damaged a lot, than change it...
    what about that "Mori Seiki Electrical circuit diagram" can you send it to me ???
    Aug 2011
    92
    Quote Originally Posted by vladimir1409 View Post
    Are the arms really that visually different? To convert a machine from Cat to BT would it just be an arm swap?
    All the documents i have are paper copies, if you need any info from them let me know and i can try to find it.
Page 1 of 5 123
  1. New (old) Milltronics owner, lots of questions
    By Brian L in forum Milltronics
    Last Post: 11-28-2011, 05:02 PM
  2. New G0602 owner with questions
    By T_Tactical in forum Benchtop Machines
    Last Post: 01-18-2011, 05:29 PM
  3. Replies: 62
    Last Post: 12-31-2010, 05:47 PM
  4. Questions and advice for a new Sherline owner
    By Fboyles in forum Mini Lathe
    Last Post: 02-20-2010, 04:26 AM
  5. MV Jr, New Owner Questions
    By andyhol in forum Mori Seiki Mills
    Last Post: 11-16-2009, 07:25 PM
