587,045 active members*
3,039 visitors online*
    Aug 2011
    multi start thread
    i supplied a multi start thread for a customer that really fell in love with the idea. he now would like me to make a 1/2 dia. shaft that will move 1 inch per revolution. has anyone had experiance with something like this?or does anyone have any ideas.maybe 1/2-4 with 4 starts ?will a 60 degree insert still be ok ? i'm open to sugestions
    thanks tom
    Apr 2009
    1262
    Your issue would be if your insert doesn't have proper clearance for the desired pitch. Your Okuma can do up to 40 IPR but may be limited by RPM and Rapid rate.
    You will also need to watch your lead in distance or acceleration curve.
    Best regards,
    Aug 2011
    i've search a little on line for a picture or some type of image the problem i see is turning the male thread there is alot of material to be removed.i found a website with ball screws that concept may be an option. turning the female thread w/062 radius cutter and making a tube with holes to locate 1/8 balls in the proper locations.
  1. multi start thread cutting on 10TF fanuc
    By calc in forum G-Code Programing
    Last Post: 06-17-2022, 02:14 PM
  2. Multi-start Thread on a Fanuc OT controller
    By Fudd in forum Uncategorised MetalWorking Machines
    Last Post: 09-18-2012, 06:35 AM
  3. ACME rods - normal start and multi-start
    By shaffin in forum Canadian Club House
    Last Post: 12-20-2010, 02:19 PM
  4. Multi start thread milling
    By colin1544 in forum Centroid CNC Control Products
    Last Post: 08-30-2010, 05:03 AM
  5. Multi-start thread?
    By DonutSlayer in forum Daewoo/Doosan
    Last Post: 03-04-2008, 05:07 AM
