586,913 active members*
2,831 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Newbie Help - Lubrication for NSK linear bearings
Results 1 to 3 of 3
    Dec 2009
    2
    Hello,
    I just bought an old, but nice cnc machine that has NSK linear bearings.
    I soaked one bearing in paint thinner to remove all of the old grease.
    I then sprayed it with garage door dry lubricant (from what I read here).
    The clean bearing is MUCH more difficult to move than a "dirty" one I haven't cleaned yet.
    I plan to use the machine for woodworking and didn't want it to attract too much sawdust although the guides are pretty well sealed from the outside.
    What kind of lubricant should I use? Regular grease?
    Thanks for your help,
    Matt
    Feb 2009
    6028
    I believe klubber is what nsk recommends. Nbu15 was common, but it is expensive. You could probably get away with white lithium grease.
    Dec 2009
    2
    Thanks underthetire.
    I think I can get that locally.
  1. linear bearings
    By coyotebait in forum WoodWorking Topics
    Last Post: 07-23-2010, 04:33 PM
  2. Haas VF Linear Guides Lubrication
    By Alex VF in forum Haas Mills
    Last Post: 11-30-2009, 08:08 AM
  3. A/C Spindle bearings and Linear rail lubrication?
    By mackeym in forum Linear and Rotary Motion
    Last Post: 03-17-2008, 03:18 PM
  4. VXB linear bearings
    By Mr.Nerd in forum DIY CNC Router Table Machines
    Last Post: 08-06-2007, 02:20 AM
  5. skate bearings versus linear bearings
    By paul langwade in forum Linear and Rotary Motion
    Last Post: 05-29-2006, 04:06 PM
