586,682 active members*
2,738 visitors online*
Results 1 to 7 of 7
    Mar 2010
    Exclamation Mach3 Modbus GS2 spindle drive
    Hello guys,
    I am in the middle of a retro-fit of and old Harbor Fright Zay7032 (Rong Fu 32 I guess) to CNC.
    The original spindle motor was defective and would kick my breaker out half the time I fired it up. I was not in love with this motor enough to warrant opening it up and trying to figure it out. I just made an adapter plate and slapped a 2 HP 56C on it with a VFD. As it was just a manual mill I started and stopped the spindle on the drive keypad as required. Now I am changing the acme's out to ballscrews and nema 34 steppers ran by Mach3.
    I read the conversation on this topic back in 2006-2007 but could not get the thing going from that.
    Is there anyone around that got it to fully work (IE direction and speed)? Any info or comments are VERY WELCOME.
    Mar 2010
    Little more info.
    My cable is 9pin RJ12
    5 2
    3 3
    2 4
    This is as per the GSoft drive configuration utility's schematic.
    Under test modbus(in Mach3) I just get read timeouts no matter the address, baud, stop bits or parity
    I am doing something wrong.
    Mar 2010
    Unhappy Pretty Please
    :drowning: I am really hung here... If anyone has done the GS2 over modbus thing, please (pretty with sugar on it) post a quick writeup of the pitfalls experienced. I have done all I can think of.
    Feb 2005
    487
    if your going to a GS2 over serial mb, you need to set the GS2 switch to 232, further you will need to match the port configs the same in both vfd and serial plugin mb.
    lastly, you will need to convert the GS2 modbus registers to decimal and address those blocks in the SPMB. Lastly, you can also do "Block" addressing in the GS2 in where you can put all the data in one continous block that you want to control, and/or monitor, then talk to that. Look at the user docs section, read the "Brains users guide", it touches on hooking up modbus stuff.
    scott
    Commercial Mach3: Screens, Wizards, Plugins, Brains,PLCs, Macros, ATC's, machine design/build, retrofit, EMC2, Prototyping. http://sites.google.com/site/volunteerfablab/
    Mar 2010
    I know this is newby stuff here, but where is the "user docs" located? Do you mean on cnczone? or on Artsoft? I could not find it with searches on either? Please a little more info on where this info is...
    I think he's referring to here:
    Member Doc's
    Mar 2010
    Thanks, I am still not getting the GS2 working but I did find a guide that mentions DL05/06 and DL205 series PLC's with network cards. I have a number of these units and install them daily. I am thinking I will throw an 06 at this and just let it control the drive with discreet points and analog speed. I just cannot believe I am unable to get the modbus serial coms working.
  1. Modbus to run GS-2 drive?
    By mecheng10 in forum Mach Mill
    Last Post: 06-17-2012, 07:01 PM
  2. Which VFD for spindle control Mach3 via Modbus
    By silyavski in forum Phase Converters
    Last Post: 07-06-2011, 01:43 PM
  3. Replies: 0
    Last Post: 06-11-2010, 03:27 AM
  4. MODBUS I/O Controller for Mach3 (MBIO)!
    By icm in forum News Announcements
    Last Post: 05-20-2009, 05:54 PM
  5. Mach3 with Hitachi VFD using Modbus
    By swinn in forum Mach Software (ArtSoft software)
    Last Post: 11-28-2008, 07:44 PM
