The gantry side plates are generally angled backwards to allow moving the center of weight of the gantry beam and router closer to the center of the carriage length. With rectangular side plates the beam can just be mounted to the rear edge of the plates or just inside between the plates. It also moves the actual cutting area rearward where it is more nearly centered on the machine table.
I built the Solsylva 25x37 using red oak instead of pine lumber and it works very well. A lot of luthiers use that plan set because the 37" dimension works better for cutting necks. I think you could easily stretch the 25x25 design to 25x36 or 25x48 if you wish to. It looks like a simpler design to build than my 25x37. Just lengthen the long axis parts to what you want and add the length that the gantry occupies so that you have at least the working length you need.
I made a lot of changes to my 25x37 like 1/2-10 ACME screws and Dumpster anti-backlash nuts, a redesigned bearing plate for the ACME screws, thrust bearings and washers, and I have had it jogging reliably at 250 ipm with a Xylotex driver and 425 oz steppers. It has 1/2-10 single start screws on it now. With a Gecko G540 driver even the 1/2-10 single start screws will give good performance. Being made of wood, it does flex under heavy cutting loads though.
Your Z axis assembly can be enhanced to handle the heavier router, or you could leave it as is and install a Dewalt DW611 1.25hp router for extra power over a regular cheap 1hp trim router. You will need to buy or make a different router mount to fit your Z axis.
CarveOne
CarveOne
