does anyone know if this is even a option?
all of our controls only have the one offset.
would be nice if it had gemetry/wear offsets but i have never seen it.
any info appreciated.
It is possible to set the tool offsets to inlude a wear column.
If you go to www. meau. com then downloads, you can
get the M520 instruction manual. You will see what's referred to
as "TOOL OFFSET MEMORY TYPE II"
You will need to change a machine parameter that's outlined in the
instruction manual.
Thanks.
do have the manual.
feel like a idiot - helps if i read it i guess.
been looking everywhere else except the manual close enough.
Is there a parameter change to have the wear offset reset to zero when its station is zero'd off ( on M50 L)
