586,494 active members*
1,615 visitors online*
Results 1 to 8 of 8
    Oct 2011
    Losing tram during milling operations?
    I know its customary to tram the mill before milling. But with high cutting forces in all axis directions, and some loose parts of the machine, wouldnt you lose tram after a while, even during a run? So isnt tramming a little bit futile?
    I havent done any 'precision' machining yet, so I just make sure my mill is relatively well trammed. But I've seen people tramming their mill by say tapping on the spindle or hammering some parts and then look back at their indicator to ensure 'perfect tram' to within the resolution of the indicator and go "wah la... perfecto!", is it a bit futile? I guess as long as the maching turns out to be within acceptable tolerances its the best you can do?
    Apr 2006
    3206
    Wow. If you lose tram while milling, you didn't tighten things down properly, or you need to lose that mill.
    Like da man says... "set it and forget it"
    Dec 2006
    839
    As long as you dont crash, or try using the machine over its ability you should be good. Of course some of these machines are a bit weak and cutting with high forces could cause some need to retram. But normally they will hold.
    Jess
    GOD Bless, and prayers for all.
    Apr 2005
    419
    As has been said, you shouldn't need to tram before milling. It is not customary to tram before machining. Its a one-time setup operation.
    If you are losing tram due to normal machining something is seriously, seriously wrong.
    Aug 2008
    292
    losing tram
    losing tram is not normal with normal milling operations
    but at
    50 sfpm
    1" diameter, 2" sticking out, 1" shank, 2 flute end mill
    milling 304 SS
    193 rpm
    max Depth of cut 0.409"
    max Feed 1.9 ipm
    estimated hp = 1.94
    end force at mill tip 855 lbs
    torque 428 in lbs
    so basically end mill is hammering at 386 beats per min at 855 lbs
    ......... slow speeds can produce enormous forces. but if you run at higher rpm's with small diameter end mills you will not normally see high forces
    Jan 2004
    3154
    Quote Originally Posted by DMF_TomB View Post
    but at
    50 sfpm
    milling 304 SS
    193 rpm
    max Feed 1.9 ipm
    estimated hp = 1.94
    torque 428 in lbs
    As was already mentioned above ^ This type of machining would only be done in a large heavy machine. Tram is not an issue.
    Anybody running a tool room mill or less is gambling heavily on serious machine breakage and is going to lose in short order.
    That scenario is like pulling your yacht through the Adirondacks with a Chevette.
    www.integratedmechanical.ca
    Aug 2008
    292
    how tram can be lost
    1) mill heavy enough that part moves in the vise and as it moves a higher and higher depth of cut happens
    2) 1/2" or bigger end mill snaps / breaks
    i'll admit it has happened to me. i even had a foreman tell me he could see the mill was out of tram from 10 feet away and it was well over 2 degrees. so now i check tram immediately if i break an end mill. i also check tram before any critical job.
    why?? because of course as you extend a quill that is out of tram you are drifting in a x and or y direction at the same time. higher tolerances recommend raising or lowering the knee rather than extending the drill quill.
    Oct 2011
    Not that I was speaking from experience or anyting. I never usually tram my mill before every job because I havent done any 'precision machining'. I mean it seems possible for some machine to lose tram over time. Then again I agree, perhaps if tram is lost after milling when everything was setup properly then the job was a little too aggressive for the machine.
    But even tramming a machine doesnt create perfection either, since there is equal and opposite reaction forces, so any sort of cutting will cause deflection of the mill/cutters and material stock to some degree so its never perfect anyway.
  1. Tram or Level?
    By behindpropeller in forum Haas Mills
    Last Post: 12-10-2010, 06:36 PM
  2. Tram, Square Cylinder & Edge Pro Tram
    By ViperTX in forum Calibration / Measurement
    Last Post: 08-12-2010, 11:13 PM
  3. Tram X2 Z axis
    By Bluedog in forum Benchtop Machines
    Last Post: 10-27-2009, 09:21 PM
  4. Losing Tram on an EZTrak DXII
    By jmorris@mailmds in forum Bridgeport / Hardinge Mills
    Last Post: 10-26-2008, 03:05 PM
