586,655 active members*
4,392 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Newbie Identifying Servo Motor
    Oct 2011
    Exclamation Newbie Identifying Servo Motor
    Hi I am looking for some info on some Pittman servo motors...
    Here is all the information I have so far..
    Pittman
    6501033
    Rev D
    24VDC
    400 CPR
    05-23-00 (Date?)
    9434J817-R1
    thanks and any information on which servo drive I'd need..I'd be very greatful..I'm not even sure what type of servo they are BLDC etc..?
    I am new to the servo motor world. :drowning:
    I have the other stuff sorted out I think..
    Here are some contenders for servo drives : -
    Tell me if they are suitable.
    DeskCNC
    GeckoDrive
    Many thanks!
    Rencio
    Oct 2011
    Ok I found some (similar looking and spec wise) models of servo (Pittman) and some datasheets...so it looks like they have inbuilt hall effect and hp encoders..but I can't be sure..
    any experienced pittman users around?
    24223
    Pittman are typically small DC brushed motors.
    The 24vdc limits them a bit.
    If you can post a shot of the encoder end it may be possible to identify the encoder?
    Al.
    Oct 2011
    Thanks for the reply Al..
    I will get a photo of the encoder soon.
    It will be for a low load application so the servos don't have to be super strong.
    If brushed dc I think I will probably go for the deskcnc drives..the encoder has 5 wires coming from it if I remember correctly - I'll have to check again over at the studio..
    If 5 wires it's probably a 2 channel encoder like on the datasheets I've seen..right?
    Ok I'm not sure about the hall sense assembly..is that to do with endstops?
    The servo has a 1 and 2 with 2 wires from each - this is different to the datasheet with hall sense.
    thanks
    Rencio
  1. Newbie- Servo motor torque question
    By byrdman73 in forum Servo Motors / Drives
    Last Post: 06-10-2009, 12:41 AM
  2. Help identifying servo
    By Wolfmarsh in forum Servo Motors / Drives
    Last Post: 03-12-2009, 02:08 PM
  3. Identifying SEM servo motor torque
    By boringmill in forum Servo Motors / Drives
    Last Post: 12-27-2006, 05:22 AM
  4. Newbie: is there difference between stepper and servo motor?
    By g888h in forum Stepper Motors / Drives
    Last Post: 09-11-2006, 01:50 AM
  5. Help identifying servo motor
    By Corvus corax in forum Servo Motors / Drives
    Last Post: 10-26-2005, 03:34 AM
