I am trying to cut 303 stainless steel using a 3/16 TiN HSS end mill. It is currently running at 1400 rpm, 11 ipm, 0.02 depth of cut. As can be seen, it is stepping the cut. Through a process of elimination, I believe this is being caused by the tool flexing. I am looking for advice on how to fix this problem, whether my rpm or ipm are wrong, and what is a reliable way to calculate these as I am entirely self taught, both in machining and CAD/CAM, and the learning curve is steep.
Thanks.
