586,140 active members*
5,570 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Robot Ouputs not controlling my gripper solenoids
    Oct 2011
    Hi
    On my training course for the fanuc robots (2 wks ago)the grippers were all controlled via robot outputs.
    I've tried the same thing with this 420-iF, using the RO[1] = on,RO[2]= off etc.. to get the solenoids to fire, but they wont.
    There are 8 RO[n] defined on the TP the rest are not defined (of 24 i think).
    Am i missing something here?
    RI and RO are pre-assigned so why would they not work?
    Would a gripper be wired into any other type of outputs?
    I have just remastered this robot, it hadnt been turned on in a long time.
    I dont know if there was software for this gripper on robot prior to remastering.
    any ideas would be great
    thanks
    Feb 2011
    640
    never used a i series- in the old Karels you have to set the user signal assignment table values for the I/O. I havent even setup a R-J in long enough that I dont recall if they needed them or not- anyway in the old Karels $USAT[87],[88]& [89] were the ones that configured hand#1...the first word says what slot the cards located in, the second the start address, and lastly the type of output- maintained/pulsed/etc...
    imagine similar settings are required for the newer ones to tell the control what kind of hand you have mounted?
  1. Setting up solenoids
    By dfurlano in forum Gecko Drives
    Last Post: 02-17-2011, 11:48 PM
  2. Latching Solenoids anyone?
    By Al_The_Man in forum CNC Machine Related Electronics
    Last Post: 11-01-2010, 01:35 AM
  3. Controlling a 6 axes Robot, what software?
    By satanicoo in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-03-2010, 03:15 AM
  4. Looking for Robot Auto Palletising (Panarobo and or STORK Robot)
    By rsarwanto in forum European Club House
    Last Post: 09-12-2008, 12:22 PM
  5. Solenoids
    By Lennart in forum Mechanical Calculations/Engineering Design
    Last Post: 03-05-2005, 10:19 PM
