586,306 active members*
3,485 visitors online*
    Nov 2005
    17
    fanuc 3m lost parameters
    Great forum!
    I am resurrecting a Tree Kira VMC 1984
    I lost the parameters on a fanuc 3m-c. Then got them reloaded.
    I need help with parameter/diagnostic adjustments to reinstate the g41/g42 on a 3m-c controller. Everything seems to be working now, except the g41/g42 which was working before the data loss. Thanks.
    24221
    PM sent, not sure if it will help?
    Al.
    Nov 2005
    17
    Thanks for that...I do not see the answer there..
    Nov 2005
    17
    At the machine now... found the 996-999 parameters (all zero's,) they did not print out when I did the backup.....Me thinks that is the source of the problem. Any Ideas?
    Nov 2005
    17
    Thanks Guy's! All fixed!
    Great forum!
  1. Lost fanuc 3T parameters
    By erikturn in forum Fanuc
    Last Post: 09-24-2014, 09:00 AM
  2. Puma 8HC Parameters lost (Fanuc OT)
    By rogo in forum Daewoo/Doosan
    Last Post: 03-17-2011, 05:37 AM
  3. Fanuc O-M lost parameters
    By macperfo in forum Fanuc
    Last Post: 03-27-2009, 12:47 AM
  4. Parameters lost in Fanuc OM
    By wicked_won in forum CNC Machining Centers
    Last Post: 03-27-2008, 10:50 PM
  5. Replies: 2
    Last Post: 02-08-2008, 09:00 AM
