587,040 active members*
2,989 visitors online*
IndustryArena Forum > CAM Software > FeatureCAM CAD/CAM > Surface over a surface problem
Results 1 to 7 of 7
    Oct 2011
    If I have a surface with a pocket and some holes and I create another surface over it to hide them when doing surface milling, why does it still pick up the features under the surface even if I raise it up .001" Any ideas anybody?
    Jun 2005
    69
    first, make sure they are not checked in the part surfaces
    Oct 2011
    Thanks for the response dcscalp, I tried with it checked and not checked. it still wants to pick the pocket up under my created surface. I fixed it by slanting the part so that surface was parallel to the table that way I wouldn't have to surface mill it.
    On the same part though, I'm milling the rest of it that's at an angle. I'm roughing with a 4 inch facemill. That's how big the part is. But instead of staying on the surfaced I've chosen, it wants to go around the side of the part where it would be cutting a lot of air. Any way around this?
    Jun 2005
    69
    this could get involved. what surface milling feature are you using? on the edges tab, do you have "don't roll over edges checked? on stock tab are you checking use "part surface dimension"? fill in some blanks---
    Oct 2011
    I'm using z level roughing, So I dont get the roll over edge option. And I've tried to use part surface, stock and the boundary options.
    Jun 2005
    69
    rather than creating a new surface that way, i go to surface wizard- one surface- untrim surface and "fill in" holes and pocket- then set the z-end if necessary. it's hard without "seeing" the file- can you attach it?
    Oct 2011
    Send me your E-mail through p.m and I'll Email it to you. Thanks.
  1. Fillet surface to surface problem
    By vincent13 in forum Mastercam
    Last Post: 02-10-2011, 01:15 PM
  2. Surface Problem
    By ZeroDay in forum Mastercam
    Last Post: 10-23-2009, 12:29 AM
  3. Surface to Surface Filleting and Trimming
    By cowpoke in forum Mastercam
    Last Post: 03-17-2009, 02:42 PM
  4. Surface finish problem
    By gar in forum Haas Mills
    Last Post: 05-22-2008, 03:01 PM
  5. ?! Please help me with this surface problem.
    By Ben J in forum Solidworks
    Last Post: 09-29-2007, 06:25 PM
