586,805 active members*
8,752 visitors online*
    Dec 2004
    126
    4th axis trigger off coolent switch?
    hears the deal I need to hook up a DIY 4th axis running off a PC to index "ONLY" and I need some way to tell the PC when to index and on my fadal VMC I have a spare 110V coolent relay that triggers off a M code .... so my idea is why not use the 110V relay to talk to a 5V switch to tell the PC to index... It looks like it well work to me
    and one tryed it ?
    Thanks Duffy
    Jul 2005
    12177
    Your idea is to have the 110V AC output operate a relay with a 110volt coil and use the contacts on the relay to switch your 5 volts. The PC looks for the presence of 5 volts at some input and indexes the 4th axis. The only problem you might find is that the relay contacts might bounce as they close; this means the PC sees 5 volts then the bounce turns it off and then on again so you might get two indexes depending on how your PC reacts to two closely spaced signals.
    1880
    use a capacitor to keep the signal from bouncing with the contactor(on the 5volts side ). It will slow the signal down but were talking milliseconds here. So it should work
    thanks
    Michael T.
    "If you don't stand for something, chances are, you'll fall for anything!"
