Have a cnc xv710 xv1000 that has an external EHWC (Electronci Hand Wheel Control) which is not working, is there an install, or engage code that is needed to have the EHWC operate with the system.
Is this the ones with the Fanuc 0i fitted? They generally have 100p/turn encoders in them, you can take the back off and check the pulses with a meter byt turning the wheel slowly.
Al.
