BEST WAY TO MILL OUT BROKEN TAP. I HAVE BEEN USING G73 WITH Q.002 WITH K.006 AT 6000 RPM AND A FEED OF 1.0. WAS WONDERING IF HELIXING WOULD BE BETTER OR DIFFERNT SPEEDS AND FEEDS IN MY G73. ON A BRIDGEPORT I RUN RPM AS FAST AS I CAN, PUT SOME TENSION ON THE QUIL LOCK AND G73 BY HAND WITH NO COOLANT AND A CARBIDE END MILL. BUT HAVE BEEN STRUGGLING ON MY HASS MILL BURNING UP MORE CARBIDE END MILLS TO GET THE JOB DONE. MAYBE I SHOULD TRY IT DRY WITH AIR LIKE ON THE BRIDGPORT. ANY SUGGESTION WOULD BE APPRECIATED....
