Hello
Some weeks ago, I send mail to syil requesting info for configure EMC. No answer given, so perhaps I´ll receive here.
I need this info for configuration, I have purchased my machine and cannot use correctly because mach3 is a poor program due to windows problems.
DRIVER INFORMATION IN NS OR MICROSECONDS
Step time
Step Space
Direction Hold
Direction Setup
Base period maximum jitter
Pin configuration I assume will be correct on x5+ manual so I´ll obvious it.
X AXIS CONFIGURATION
Motor steps per revolution
Driver microstepping
Leadscrew pitch mm/rev
Maximun velocity mm/s
Maximum Acceleration mm/s2
Y AXIS CONFIGURATION
Z AXIS CONFIGURATION
A AXIS CONFIGURATION
SPINDLE CONFIGURATION
PWM Rate Hz
Thanks for your attention.
Cheers
Pablo
