Hi!
My motor-mounts (MTR-0068) on 4020HT are running out.
I think I would made new solid mounts.
Does anyone have the dimensions of it?
I would get it out to measure, install again, make the mounts...
Thomas
Hi!
Thomas
Get' m from the old ones!
Ohh thanks!Get' m from the old ones!
So I have to get them out, measure, install old mounts back,
make new mounts with the machine, get old out again and then
install new mounts.
Thats the reason to ask for the dimensions....
Thomas
You don't have to remove the motor, plate; get the two stnd offs from left side, hold the motor plate with a block, get you dims and put it back; that simple.
Ahh okay - thats a good idea!
I'll try it.....
Is there a chance to change both mounts without remove motor complete?
Okay - the left side will be simple - but the right side?
you can do the same on the right side, the roller asssy is holding the plate with one bolt
so get four block the same haith as the mounts and stand offs.,
finished, was easier than I thought
thanks!
Thomas
