586,804 active members*
8,179 visitors online*
Results 1 to 20 of 39
    Oct 2011
    Angry need help thread milling
    hello peoples, im new here. not sure if im in the right spot. im having trouble with threadmilling. im fairly new to the programing side of this stuff. im using the advent thread milling software and an advent threadmill. for some reason it keeps cutting my 5/8-18 thread off center of my hole. ive used it before to cut some npt threads with no problems. but trying to cut the straight un thread is giving me hell. no matter what i do or change it cuts off center everytime. i dont understand what the problem is can anyone please help completly lost. brian
    Jul 2005
    12177
    You need to post the code so people can see what it is, also where your work zero is located.
    I program my own code for straight thread milling and normally put the work zero at the center of the hole. Then the I in the G02/3 is the same as the G01 X move that puts the cutter at the thread radius, or J the same as X. You just have to remember they are opposite signs.
    Oct 2011
    my reply to need help
    the work zero is the center of the hole. everything runs of that work zero. i drill the hole then endmill it out to size. the threadmill comes in the same work zero then cuts the threads way off center. give me a few and i will post the code. i use gibbscam for all my programing and advent for the threadmill. simply cuz i cant figure out how to do it in gibbs. im very new to this software and have never programmed before 4 or 5 months ago. ive been running machines for over 10 years and recently took over a shop. i have no help here and have to learn it all on my own. thus far ive been moderatly succesful until the threadmill has come into play. thanks for the help thus far. program will folow soon.
    Oct 2011
    my g-code post
    here is my complete program. its for a hurco ultimax. everything is good and proven except the thread mill.
    / PROGRAM: 100970-5 FIX.NCF
    / .625-11 THREAD AND RELIEF
    / FORMAT: HURCO ULTIMAX BMC40
    / 10/10/11 AT 10:04 AM BP
    / OUTPUT IN ABSOLUTE INCHES
    / PARTS PROGRAMMED: 1
    / FIRST TOOL NOT IN SPINDLE
    / OPERATION 1: HOLES
    / WORKGROUP
    / TOOL 1: .0781 CENTER DRILL
    / #2 CENTER DRILL
    / CS#1 - XY PLANE
    N19G0G17G70G90S500T1M6
    N20G75M3
    N21X0.Y0.Z1.
    N22Z.1 M8
    N23G83X0.Y0.Z.18Z.0179F.5
    N24G80
    N25G0Z.1
    / OPERATION 2: HOLES
    / WORKGROUP
    / #2 CENTER DRILL
    / CS#1 - XY PLANE
    N26G90G0X0.Y-.402
    N27Z.1
    N28G83X0.Y-.402Z.18Z.0179F.5
    N29G80
    N30G0Z.1
    / OPERATION 3: HOLES
    / WORKGROUP
    / #2 CENTER DRILL
    / CS#1 - XY PLANE
    N31G90G0X.402Y0.
    N32Z.1
    N33G83X.402Y0.Z.18Z.0179F.5
    N34G80
    N35G0Z.1
    N36M9
    N37M25
    N38G0
    N39M0
    N40T2M6
    / OPERATION 4: HOLES
    / WORKGROUP
    / TOOL 2: .093 DRILL
    / 3/32 .093 DRILL
    / CS#1 - XY PLANE
    N41S1848M3
    N42G90G0X0.Y-.402
    N43Z1.
    N44Z.1 M8
    N45G83X0.Y-.402Z.35Z.0213F1.9
    N46G80
    N47G0Z.1
    / OPERATION 5: HOLES
    / WORKGROUP
    / 3/32 .093 DRILL
    / CS#1 - XY PLANE
    N48G90G0X.402Y0.
    N49Z.1
    N50G83X.402Y0.Z.35Z.0213F1.9
    N51G80
    N52G0Z.1
    N53M9
    N54M25
    N55G0
    N56M0
    N57T3M6
    / OPERATION 6: HOLES
    / WORKGROUP
    / TOOL 3: .4375 DRILL
    / 7/16 DRILL
    / CS#1 - XY PLANE
    N58S480M3
    N59G90G0X0.Y0.
    N60Z1.
    N61Z.1 M8
    N62G83X0.Y0.Z.615Z.1F1.
    N63G80
    N64G0Z.1
    N65M9
    N66M25
    N67G0
    N68M0
    N69T4M6
    / OPERATION 7: HOLES
    / WORKGROUP
    / TOOL 4: .125 DRILL
    / .125 DRILL
    / CS#1 - XY PLANE
    N70S1375M3
    N71G90G0X0.Y0.
    N72Z1.
    N73Z.1 M8
    N74G83X0.Y0.Z.99Z.0286F1.4
    N75G80
    N76G0Z.1
    N77M9
    N78M25
    N79G0
    N80M0
    N81T5M6
    / OPERATION 8: CONTOUR
    / WORKGROUP
    / TOOL 5: .5 ROUGH ENDMILL
    / .5 ROUGH ENDMILL
    / CS#1 - XY PLANE
    N82S1528M3
    N83G90G0X.0092Y.0042
    N84Z1.
    N85Z.1 M8
    N86G1Z-.045F.5
    N87G41X.0037Y.0126
    N88G3G17X-.0047Y.0171I-.0047J.0071
    N89G17X-.0101Y.0155I-.0047J.0071
    N90G17X-.0185Y0.I0.J0.F6.1
    N91G17X0.Y-.0185I0.J0.
    N92G17X.0185Y0.I0.J0.
    N93G17X0.Y.0185I0.J0.
    N94G17X-.0101Y.0155I0.J0.
    N95G17X-.0185Y0.I0.J0.
    N96G17X0.Y-.0185I0.J0.
    N97G17X.0185Y0.I0.J0.
    N98G17X0.Y.0185I0.J0.
    N99G17X-.0101Y.0155I0.J0.
    N100G17X-.0147Y.0071I-.0047J.0071
    N101G17X-.013Y.0016I-.0047J.0071
    N102G40G1X-.0075Y-.0067
    N103G0Z.1
    N104X.0092Y.0042
    N105Z-.045
    N106G1Z-.09F.5
    N107G41X.0037Y.0126
    N108G3G17X-.0047Y.0171I-.0047J.0071
    N109G17X-.0101Y.0155I-.0047J.0071
    N110G17X-.0185Y0.I0.J0.F6.1
    N111G17X0.Y-.0185I0.J0.
    N112G17X.0185Y0.I0.J0.
    N113G17X0.Y.0185I0.J0.
    N114G17X-.0101Y.0155I0.J0.
    N115G17X-.0185Y0.I0.J0.
    N116G17X0.Y-.0185I0.J0.
    N117G17X.0185Y0.I0.J0.
    N118G17X0.Y.0185I0.J0.
    N119G17X-.0101Y.0155I0.J0.
    N120G17X-.0147Y.0071I-.0047J.0071
    N121G17X-.013Y.0016I-.0047J.0071
    N122G40G1X-.0075Y-.0067
    N123G0Z.1
    N124X.0092Y.0042
    N125Z-.09
    N126G1Z-.135F.5
    N127G41X.0037Y.0126
    N128G3G17X-.0047Y.0171I-.0047J.0071
    N129G17X-.0101Y.0155I-.0047J.0071
    N130G17X-.0185Y0.I0.J0.F6.1
    N131G17X0.Y-.0185I0.J0.
    N132G17X.0185Y0.I0.J0.
    N133G17X0.Y.0185I0.J0.
    N134G17X-.0101Y.0155I0.J0.
    N135G17X-.0185Y0.I0.J0.
    N136G17X0.Y-.0185I0.J0.
    N137G17X.0185Y0.I0.J0.
    N138G17X0.Y.0185I0.J0.
    N139G17X-.0101Y.0155I0.J0.
    N140G17X-.0147Y.0071I-.0047J.0071
    N141G17X-.013Y.0016I-.0047J.0071
    N142G40G1X-.0075Y-.0067
    N143G0Z.1
    N144X.0092Y.0042
    N145Z-.135
    N146G1Z-.18F.5
    N147G41X.0037Y.0126
    N148G3G17X-.0047Y.0171I-.0047J.0071
    N149G17X-.0101Y.0155I-.0047J.0071
    N150G17X-.0185Y0.I0.J0.F6.1
    N151G17X0.Y-.0185I0.J0.
    N152G17X.0185Y0.I0.J0.
    N153G17X0.Y.0185I0.J0.
    N154G17X-.0101Y.0155I0.J0.
    N155G17X-.0185Y0.I0.J0.
    N156G17X0.Y-.0185I0.J0.
    N157G17X.0185Y0.I0.J0.
    N158G17X0.Y.0185I0.J0.
    N159G17X-.0101Y.0155I0.J0.
    N160G17X-.0147Y.0071I-.0047J.0071
    N161G17X-.013Y.0016I-.0047J.0071
    N162G40G1X-.0075Y-.0067
    N163G0Z.1
    N164X.0092Y.0042
    N165Z-.18
    N166G1Z-.225F.5
    N167G41X.0037Y.0126
    N168G3G17X-.0047Y.0171I-.0047J.0071
    N169G17X-.0101Y.0155I-.0047J.0071
    N170G17X-.0185Y0.I0.J0.F6.1
    N171G17X0.Y-.0185I0.J0.
    N172G17X.0185Y0.I0.J0.
    N173G17X0.Y.0185I0.J0.
    N174G17X-.0101Y.0155I0.J0.
    N175G17X-.0185Y0.I0.J0.
    N176G17X0.Y-.0185I0.J0.
    N177G17X.0185Y0.I0.J0.
    N178G17X0.Y.0185I0.J0.
    N179G17X-.0101Y.0155I0.J0.
    N180G17X-.0147Y.0071I-.0047J.0071
    N181G17X-.013Y.0016I-.0047J.0071
    N182G40G1X-.0075Y-.0067
    N183G0Z.1
    N184X.0092Y.0042
    N185Z-.225
    N186G1Z-.27F.5
    N187G41X.0037Y.0126
    N188G3G17X-.0047Y.0171I-.0047J.0071
    N189G17X-.0101Y.0155I-.0047J.0071
    N190G17X-.0185Y0.I0.J0.F6.1
    N191G17X0.Y-.0185I0.J0.
    N192G17X.0185Y0.I0.J0.
    N193G17X0.Y.0185I0.J0.
    N194G17X-.0101Y.0155I0.J0.
    N195G17X-.0185Y0.I0.J0.
    N196G17X0.Y-.0185I0.J0.
    N197G17X.0185Y0.I0.J0.
    N198G17X0.Y.0185I0.J0.
    N199G17X-.0101Y.0155I0.J0.
    N200G17X-.0147Y.0071I-.0047J.0071
    N201G17X-.013Y.0016I-.0047J.0071
    N202G40G1X-.0075Y-.0067
    N203G0Z.1
    N204M9
    N205M25
    N206G0
    N207M0
    N208T6M6
    / OPERATION 9: CONTOUR
    / WORKGROUP
    / TOOL 6: .375 ROUGH ENDMILL
    / .375 END MILL FINISH BOTTOM
    / CS#1 - XY PLANE
    N209S2037M3
    N210G90G0X-.0016Y-.034
    N211Z1.
    N212Z.1 M8
    GO -.25
    N213G1Z-.274F.5
    N214G41X.0009Y-.0437
    N215G3G17X.0106Y-.0512I.0106J-.0412
    N216G17X.0131Y-.0508I.0106J-.0412
    N217G17X.0525Y0.I0.J0.F8.2
    N218G17X0.Y.0525I0.J0.
    N219G17X-.0525Y0.I0.J0.
    N220G17X0.Y-.0525I0.J0.
    N221G17X.0131Y-.0508I0.J0.
    N222G17X.0525Y0.I0.J0.
    N223G17X0.Y.0525I0.J0.
    N224G17X-.0525Y0.I0.J0.
    N225G17X0.Y-.0525I0.J0.
    N226G17X.0131Y-.0508I0.J0.
    N227G17X.0206Y-.0412I.0106J-.0412
    N228G17X.0203Y-.0387I.0106J-.0412
    N229G40G1X.0178Y-.029
    N230G0Z.1
    N231X-.0016Y-.034
    N232Z-.275
    N233G1Z-.298F.5
    N234G41X.0009Y-.0437
    N235G3G17X.0106Y-.0512I.0106J-.0412
    N236G17X.0131Y-.0508I.0106J-.0412
    N237G17X.0525Y0.I0.J0.F8.2
    N238G17X0.Y.0525I0.J0.
    N239G17X-.0525Y0.I0.J0.
    N240G17X0.Y-.0525I0.J0.
    N241G17X.0131Y-.0508I0.J0.
    N242G17X.0525Y0.I0.J0.
    N243G17X0.Y.0525I0.J0.
    N244G17X-.0525Y0.I0.J0.
    N245G17X0.Y-.0525I0.J0.
    N246G17X.0131Y-.0508I0.J0.
    N247G17X.0206Y-.0412I.0106J-.0412
    N248G17X.0203Y-.0387I.0106J-.0412
    N249G40G1X.0178Y-.029
    N250G0Z.1
    N251X-.0016Y-.034
    N252Z-.290
    N253G1Z-.322F.5
    N254G41X.0009Y-.0437
    N255G3G17X.0106Y-.0512I.0106J-.0412
    N256G17X.0131Y-.0508I.0106J-.0412
    N257G17X.0525Y0.I0.J0.F8.2
    N258G17X0.Y.0525I0.J0.
    N259G17X-.0525Y0.I0.J0.
    N260G17X0.Y-.0525I0.J0.
    N261G17X.0131Y-.0508I0.J0.
    N262G17X.0525Y0.I0.J0.
    N263G17X0.Y.0525I0.J0.
    N264G17X-.0525Y0.I0.J0.
    N265G17X0.Y-.0525I0.J0.
    N266G17X.0131Y-.0508I0.J0.
    N267G17X.0206Y-.0412I.0106J-.0412
    N268G17X.0203Y-.0387I.0106J-.0412
    N269G40G1X.0178Y-.029
    N270G0Z.1
    N271X-.0016Y-.034
    N272Z-.32
    N273G1Z-.346F.5
    N274G41X.0009Y-.0437
    N275G3G17X.0106Y-.0512I.0106J-.0412
    N276G17X.0131Y-.0508I.0106J-.0412
    N277G17X.0525Y0.I0.J0.F8.2
    N278G17X0.Y.0525I0.J0.
    N279G17X-.0525Y0.I0.J0.
    N280G17X0.Y-.0525I0.J0.
    N281G17X.0131Y-.0508I0.J0.
    N282G17X.0525Y0.I0.J0.
    N283G17X0.Y.0525I0.J0.
    N284G17X-.0525Y0.I0.J0.
    N285G17X0.Y-.0525I0.J0.
    N286G17X.0131Y-.0508I0.J0.
    N287G17X.0206Y-.0412I.0106J-.0412
    N288G17X.0203Y-.0387I.0106J-.0412
    N289G40G1X.0178Y-.029
    N290G0Z.1
    N291X-.0016Y-.034
    N292Z-.340
    N293G1Z-.37F.5
    N294G41X.0009Y-.0437
    N295G3G17X.0106Y-.0512I.0106J-.0412
    N296G17X.0131Y-.0508I.0106J-.0412
    N297G17X.0525Y0.I0.J0.F8.2
    N298G17X0.Y.0525I0.J0.
    N299G17X-.0525Y0.I0.J0.
    N300G17X0.Y-.0525I0.J0.
    N301G17X.0131Y-.0508I0.J0.
    N302G17X.0525Y0.I0.J0.
    N303G17X0.Y.0525I0.J0.
    N304G17X-.0525Y0.I0.J0.
    N305G17X0.Y-.0525I0.J0.
    N306G17X.0131Y-.0508I0.J0.
    N307G17X.0206Y-.0412I.0106J-.0412
    N308G17X.0203Y-.0387I.0106J-.0412
    N309G40G1X.0178Y-.029
    N310G0Z.1
    N311X-.0016Y-.034
    N312Z-.36
    N313G1Z-.394F.5
    N314G41X.0009Y-.0437
    N315G3G17X.0106Y-.0512I.0106J-.0412
    N316G17X.0131Y-.0508I.0106J-.0412
    N317G17X.0525Y0.I0.J0.F8.2
    N318G17X0.Y.0525I0.J0.
    N319G17X-.0525Y0.I0.J0.
    N320G17X0.Y-.0525I0.J0.
    N321G17X.0131Y-.0508I0.J0.
    N322G17X.0525Y0.I0.J0.
    N323G17X0.Y.0525I0.J0.
    N324G17X-.0525Y0.I0.J0.
    N325G17X0.Y-.0525I0.J0.
    N326G17X.0131Y-.0508I0.J0.
    N327G17X.0206Y-.0412I.0106J-.0412
    N328G17X.0203Y-.0387I.0106J-.0412
    N329G40G1X.0178Y-.029
    N330G0Z.1
    N331X-.0016Y-.034
    N332Z-.39
    N333G1Z-.418F.5
    N334G41X.0009Y-.0437
    N335G3G17X.0106Y-.0512I.0106J-.0412
    N336G17X.0131Y-.0508I.0106J-.0412
    N337G17X.0525Y0.I0.J0.F8.2
    N338G17X0.Y.0525I0.J0.
    N339G17X-.0525Y0.I0.J0.
    N340G17X0.Y-.0525I0.J0.
    N341G17X.0131Y-.0508I0.J0.
    N342G17X.0525Y0.I0.J0.
    N343G17X0.Y.0525I0.J0.
    N344G17X-.0525Y0.I0.J0.
    N345G17X0.Y-.0525I0.J0.
    N346G17X.0131Y-.0508I0.J0.
    N347G17X.0206Y-.0412I.0106J-.0412
    N348G17X.0203Y-.0387I.0106J-.0412
    N349G40G1X.0178Y-.029
    N350G0Z.1
    N351X-.0016Y-.034
    N352Z-.41
    N353G1Z-.442F.5
    N354G41X.0009Y-.0437
    N355G3G17X.0106Y-.0512I.0106J-.0412
    N356G17X.0131Y-.0508I.0106J-.0412
    N357G17X.0525Y0.I0.J0.F8.2
    N358G17X0.Y.0525I0.J0.
    N359G17X-.0525Y0.I0.J0.
    N360G17X0.Y-.0525I0.J0.
    N361G17X.0131Y-.0508I0.J0.
    N362G17X.0525Y0.I0.J0.
    N363G17X0.Y.0525I0.J0.
    N364G17X-.0525Y0.I0.J0.
    N365G17X0.Y-.0525I0.J0.
    N366G17X.0131Y-.0508I0.J0.
    N367G17X.0206Y-.0412I.0106J-.0412
    N368G17X.0203Y-.0387I.0106J-.0412
    N369G40G1X.0178Y-.029
    N370G0Z.1
    N371X-.0016Y-.034
    N372Z-..435
    N373G1Z-.466F.5
    N374G41X.0009Y-.0437
    N375G3G17X.0106Y-.0512I.0106J-.0412
    N376G17X.0131Y-.0508I.0106J-.0412
    N377G17X.0525Y0.I0.J0.F8.2
    N378G17X0.Y.0525I0.J0.
    N379G17X-.0525Y0.I0.J0.
    N380G17X0.Y-.0525I0.J0.
    N381G17X.0131Y-.0508I0.J0.
    N382G17X.0525Y0.I0.J0.
    N383G17X0.Y.0525I0.J0.
    N384G17X-.0525Y0.I0.J0.
    N385G17X0.Y-.0525I0.J0.
    N386G17X.0131Y-.0508I0.J0.
    N387G17X.0206Y-.0412I.0106J-.0412
    N388G17X.0203Y-.0387I.0106J-.0412
    N389G40G1X.0178Y-.029
    N390G0Z.1
    N391X-.0016Y-.034
    N392Z-.46
    N393G1Z-.49F.5
    N394G41X.0009Y-.0437
    N395G3G17X.0106Y-.0512I.0106J-.0412
    N396G17X.0131Y-.0508I.0106J-.0412
    N397G17X.0525Y0.I0.J0.F8.2
    N398G17X0.Y.0525I0.J0.
    N399G17X-.0525Y0.I0.J0.
    N400G17X0.Y-.0525I0.J0.
    N401G17X.0131Y-.0508I0.J0.
    N402G17X.0525Y0.I0.J0.
    N403G17X0.Y.0525I0.J0.
    N404G17X-.0525Y0.I0.J0.
    N405G17X0.Y-.0525I0.J0.
    N406G17X.0131Y-.0508I0.J0.
    N407G17X.0206Y-.0412I.0106J-.0412
    N408G17X.0203Y-.0387I.0106J-.0412
    N409G40G1X.0178Y-.029
    N410G0Z.1
    N411X-.0016Y-.034
    N412Z-.48
    N413G1Z-.514F.5
    N414G41X.0009Y-.0437
    N415G3G17X.0106Y-.0512I.0106J-.0412
    N416G17X.0131Y-.0508I.0106J-.0412
    N417G17X.0525Y0.I0.J0.F8.2
    N418G17X0.Y.0525I0.J0.
    N419G17X-.0525Y0.I0.J0.
    N420G17X0.Y-.0525I0.J0.
    N421G17X.0131Y-.0508I0.J0.
    N422G17X.0525Y0.I0.J0.
    N423G17X0.Y.0525I0.J0.
    N424G17X-.0525Y0.I0.J0.
    N425G17X0.Y-.0525I0.J0.
    N426G17X.0131Y-.0508I0.J0.
    N427G17X.0206Y-.0412I.0106J-.0412
    N428G17X.0203Y-.0387I.0106J-.0412
    N429G40G1X.0178Y-.029
    N430G0Z.1
    N431M9
    N432M25
    N433G0
    N434M0
    N435T7M6
    /.375 KEY CUTTER
    /THREAD RELIEF
    /.375X.0625WOODRUFF
    N261G0G17G70G90S360
    N262G75M3
    N263X0.Y0.
    N264Z1.
    N265Z.1 M8
    N266G1Z-.33F.7
    N267G41X.1275
    N268G3G17X0.Y.1275I0.J0.
    N269G17X-.1275Y0.I0.J0.
    N270G17X0.Y-.1275I0.J0.
    N271G17X.1275Y0.I0.J0.
    N272G40G1X0.
    N273G0Z.1
    N274M9
    N275M25
    N276M5
    N277 T8M6
    N278 M0
    / OPERATION 10: HOLES
    / WORKGROUP
    / ADVENT 5-8--11 THREADMILL
    N436 G00 X0.0000 Y0.0000
    N437 Z1.0
    N438 Z.1 M8
    N439 S1543 M3
    N440 Z-0.2845
    N441 G1 X0.0014 Y-0.0047
    N442 G41 D28 X0.0072 Y-0.0238 F4.9
    N443 G3 X0.0470 Y0.0000 Z-0.2700 I0.0128 J0.0238 F0.5
    N444 Z-0.2144 I-0.0470 J-0.0000 F0.8
    N445 X0.0072 Y0.0238 Z-0.1999 I-0.0270 J-0.0000 F0.5
    N446 G1 G40 X0.0000 Y0.0000 F40.0
    N447 G0 Z-0.2863
    N448 G1 X0.0006 Y-0.0049
    N449 G41 D28 X0.0031 Y-0.0247 F4.9
    N450 G3 X0.0560 Y0.0000 Z-0.2700 I0.0207 J0.0247 F0.6
    N451 Z-0.2144 I-0.0560 J-0.0000 F0.9
    N452 X0.0031 Y0.0247 Z-0.1982 I-0.0322 J-0.0000 F0.6
    N453 G1 G40 X0.0000 Y0.0000 F40.0
    N454 G0 Z-0.2871
    N455 G1 X0.0003 Y-0.0049
    N456 G41 D28 X0.0015 Y-0.0249 F4.9
    N457 G3 X0.0620 Y0.0000 Z-0.2700 I0.0251 J0.0249 F0.6
    N458 Z-0.2144 I-0.0620 J-0.0000 F1.0
    N459 X0.0015 Y0.0249 Z-0.1974 I-0.0354 J-0.0000 F0.6
    N460 G1 G40 X0.0000 Y0.0000 F40.0
    N461 G0 Z-0.2874
    N462 G1 X0.0001 Y-0.0049
    N463 G41 D28 X0.0007 Y-0.0249 F4.9
    N464 G3 X0.0650 Y0.0000 Z-0.2700 I0.0273 J0.0249 F0.6
    N465 Z-0.2144 I-0.0650 J-0.0000 F1.0
    N466 X0.0007 Y0.0249 Z-0.1970 I-0.0370 J-0.0000 F0.6
    N467 G1 G40 X0.0000 Y0.0000 F40.0
    N468 G0 Z0.0100 M5
    N469M9
    N470M25
    N471G90G0M5
    N472M2
    E
    Feb 2008
    267
    One thing that looks confusing to me is that you are programming a 5/8-18, you are using radius comp, yet your programmed radius is only .065 seen here...
    If you have a radius value in your offset, but the program is not really expecting one, this can make the results counter-intuative i.e. they look all screwed up.
    Look into that and post back here
    Control the process, not the product!
    Machining is more science than art, master the science and the artistry will be evident.
    Oct 2011
    newbie
    ok im sorry but im not really understanding what ur saying. it spits out radious comp. on the software automaticaly. do i need to take out the radius comp. cuz i have done this and it doesnt change anything. ive been fighting this for about 2 weeks now.very frustrated. like i said ive never programmed before about 4 months ago. so all this is very new to me and confusing. i used the advent software with the advent thread mill to program that part of it.
    Feb 2008
    267
    If D28 is offset 28, then make sure that there is no radius value in that offset and run one like that, i.e. do not change the program, just make the radius value 0.
    Let us know what that does
    Oct 2011
    radius value
    the value is 0 in the offset. no offset has been put in it
    May 2004
    4519
    Take a look at the GibbsCAM file and the G-code file in the attached ZIP file.
    Attached Files Attached Files
    May 2004
    4519
    Some of the thread milling routines do not use the center of the circle as the center of the arc for cutting. This may be why you think it is cutting off center is because in a way it is.
    Here is some info that might help: http://www.vardexusa.com/vardex-pdf/Hand_Book__mm.pdf
    Oct 2011
    ok i looked at it tho it doesnt offer much help cuz the g-code is for a fanuc where i have a hurco ultimax. i see the concept tho and will try it i gibbs. the hurco post and the fanuc post are 2 completly different posts thanks for the help i will see what i can come up with.
    Oct 2011
    txcncman
    ok so if its doing that then how do u correct that and make it cut on the center of the hole like its supposed to?
    May 2004
    4519
    Quote Originally Posted by brianp-jag View Post
    I was trying to explain that even though the numbers seem that the center of cutting will be off center by 0.015 that the software adjusts the endpoint of the arc to compensate for this. I am trying to find a formula now that explains this better.
    Jul 2005
    12177
    I copied the code for tools 7 and 8 and ran it in my simulator and I don't know how you got it to run.
    Look at lines N263 to N272.
    The machine moves to X0. Y0. on N263 so it is at the work zero.
    Then on N267 it moves to X0.1275. (There is a G41 in this line but I don't see a D value so the G41 is not doing anything. But that will not stop the code running.)
    Now on N268 a G03 move is supposed to go through an arc of 90 degrees from X0.1275 Y0. to X0. Y0.1275. But in your code both the I and J values are zero.
    If the machine is at X0.1275 and the work zero is at the center of the hole the I value has to be -0.1275.
    Same idea for lines N269, N270 and N271. The I has to be the opposite of the X value at the start of the arc or the J has to be the opposite of the Y value at the start of the arc.
    When I edited these lines like below the code ran okay. The tool 7 the Woodruff cutter did a complete circle of four arcs around the work zero then the thread mill did four passes also around the work zero.
    N267 G41 X0.1275
    N268 G03 G17 X0. Y0.1275 I-0.1275 J0.
    N269 G17 X-0.1275 Y0. I0. J-0.1275
    N270 G17 X0. Y-0.1275 I0.1275 J0.
    N271 G17 X0.1275 Y0. I0. J0.1275
    N272 G40 G01 X0.
    I found the code for a 7/16" drill but I didn't find the code for milling the hole out to the size for threadmilling.
    May 2004
    4519
    Here is posted for a Hurco:
    ( PROGRAM: THREAD_MILLING.NCF )
    ( FORMAT: HURCO ULTIMAX 3 [ID] MZ75.89.PST )
    ( 10/11/11 AT 9:24 AM )
    ( OUTPUT IN ABSOLUTE INCHES )
    ( PARTS PROGRAMMED: 1 )
    ( FIRST TOOL NOT IN SPINDLE )
    ( OPERATION 1: THREADING )
    ( WORKGROUP )
    ( TOOL 1: .375 THREAD MILL )
    N5G0G17G70G90S3000T1M6
    N10G75M3
    N15G54
    N20X0.Y0.Z.25M8
    ( CYCLE START )
    N25G41X0.Y0.
    N30G91
    N35G1Z-.8914F5.
    N40G0X.0221Y.0221
    N45G1X.0042Y.0021 (<-----NOTE STARTING POINT IS OFF CENTER)
    N50G3G17X.0275Y.047Z.0066I-.0263J.047
    N55G17X-.0538Y.0538Z.0098I-.0538J0.
    N60G17X-.125Y-.125Z.0227I0.J-.125
    N65G17X.125Y-.125Z.0228I.125J0.
    N70G17X.125Y.125Z.0227I0.J.125
    N75G17X-.125Y.125Z.0227I-.125J0.
    N80G17X-.125Y-.125Z.0227I0.J-.125
    N85G17X.125Y-.125Z.0228I.125J0.
    N90G17X.125Y.125Z.0227I0.J.125
    N95G17X-.125Y.125Z.0227I-.125J0.
    N100G17X-.125Y-.125Z.0227I0.J-.125
    N105G17X.125Y-.125Z.0228I.125J0.
    N110G17X.125Y.125Z.0227I0.J.125
    N115G17X-.125Y.125Z.0227I-.125J0.
    N120G17X-.125Y-.125Z.0228I0.J-.125
    N125G17X.125Y-.125Z.0227I.125J0.
    N130G17X.125Y.125Z.0227I0.J.125
    N135G17X-.125Y.125Z.0227I-.125J0.
    N140G17X-.125Y-.125Z.0228I0.J-.125
    N145G17X.125Y-.125Z.0227I.125J0.
    N150G17X.125Y.125Z.0227I0.J.125
    N155G17X-.125Y.125Z.0227I-.125J0.
    N160G17X-.125Y-.125Z.0228I0.J-.125
    N165G17X.125Y-.125Z.0227I.125J0.
    N170G17X.125Y.125Z.0227I0.J.125
    N175G17X-.125Y.125Z.0228I-.125J0.
    N180G17X-.125Y-.125Z.0227I0.J-.125
    N185G17X.125Y-.125Z.0227I.125J0.
    N190G17X.125Y.125Z.0227I0.J.125
    N195G17X-.125Y.125Z.0228I-.125J0.
    N200G17X-.125Y-.125Z.0227I0.J-.125
    N205G17X.125Y-.125Z.0227I.125J0.
    N210G17X.125Y.125Z.0227I0.J.125
    N215G17X-.1054Y.1235Z.0205I-.125J0.
    N220G17X-.0085Y.0006Z.001I-.0085J-.0532
    N225G17X-.0538Y-.0538Z.0098I0.J-.0538
    N230G17X.0205Y-.0423Z.0056I.0538J0.
    N235G1X.0038Y-.0027
    N240G40G0X.0184Y-.0253
    N245G90Z.25
    N250M9
    N255M25
    N260G90X0.Y0.M5
    N265M2
    E
    ( FILE LENGTH: 1815 CHARACTERS )
    ( FILE LENGTH: 15.41 FEET )
    ( FILE LENGTH: 4.77 METERS )
    May 2004
    4519
    Here is what the above code looks like in graphic.
    Oct 2011
    ok guys i greatly appreciate ur help on this tho u have me completly lost. im so in the box right now that i just dont understand it. im so sorry for this. im so confused its not even funny. tho i do appreciate ur help very very much. would it b to much to ask that someone programed the thread mill for me. the tool is .495 cutting diamiter 1" thread lenght on the tool. the threads must be .32 deep. its a hurco ultimax post. i can cut and paste from there. so sorry for the confusion. this is still very new to me. basic stuff is not a problem for me but this goes beyond what i know and im not ashamed to admit that. ive been trying on gibbs for 2 weeks now to do this and just cant figure it out.please help if anymore info is needed please contact me at 713-966-9189. much much appreciated brian at jaguar
    Jul 2005
    12177
    Quote Originally Posted by ProProcess View Post
    With CAM output this is common. The tool diameter/radius is incorporated into the code so really tool comp is not needed. But tool comp is called so that it is possible to use wear for adjusting the size. Of course for this the value in the D register has to be zero.
    Regarding the comment further up by txcncman; thread milling routines do not use the center of the circle as the center of the arc for cutting.
    You do have to use the center of the circle for cutting the actual. However threadmill programs do a tangential entry. That is they move slightly away from center to set tool comp, this is the starting point. Then they make either a 90 degree arc or a 180 degree arc that ends with the tool at the correct radius for the thread. Then they do complete circle(s) with the Z motion for the pitch. (Or they do a series of arcs to make up complete circles depending on the machine.) After doing one or two complete circles to cut the thread they then do an arc that brings them back to the starting point and cancel tool comp back to to the center. This code does that four times.
    Because the first arc, which moves from the start point out to the thread radius is not around the center point it is confusing to watch it.
    I made a video of the simulator screen which shows tool 7 doing a complete circle then tool 8 doing the offset tangential entry and departure four times.
    [ame=http://www.youtube.com/watch?v=XcfGtlK9d84]MVI 1363 - YouTube[/ame]
    Oct 2011
    thanks geof
    thats what it looks like when i use the advent software. however when i put it on the machie its different on the thread mill and comes out of center. all of u guys have been very helpful but i am still very lost and confused. you guys have so much more knowledge than i do on this stuff so it is very confusing and im about to pull my hair out becuz of it. i appreciate the help very much and dont know how i can repay you guys for this help. i was litterally thrown to the wolfes on this stuff in this shop. if i wanted to keep a job i had to figure this stuff out. ive had a very hard time doin this simply cuz im not a computer guy. i have enough trouble getting my email let alone using this kind of software. im a machinist not a programmer.im trying very hard to get it but its very slow learning and frustrating as all hell. thanks again and i hope i havnt pissed anybody off becuz of my lack of knowledge thanks brian
    May 2004
    4519
    I am willing to walk you through manual G-coding so that you get what you think you want. But I am willing to bet the G-code you have will work just fine. You confidence is lacking because of your experience level.
  1. thread milling
    By rylanrouge in forum Uncategorised MetalWorking Machines
    Last Post: 10-13-2010, 05:54 PM
  2. Thread Milling
    By mrsammy in forum Mastercam
    Last Post: 07-21-2010, 03:48 AM
  3. npt thread milling help
    By MIKEPETTY in forum Haas Mills
    Last Post: 07-19-2010, 06:05 PM
  4. thread milling
    By fourperf in forum Fadal
    Last Post: 03-11-2008, 01:14 AM
  5. Thread Milling 3/8-18 NPT
    By shawn in forum G-Code Programing
    Last Post: 08-26-2006, 02:24 PM
