586,499 active members*
3,233 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > 4th axis setup G540 and Mach3
    Sep 2007
    64
    Hello,
    I'm in the process of building a CNC table for my plasma cutter. I am using a Gecko G540 along with Mach3. This will be a 3 axis machine however the Y axis will use two steppers; one on each side of the table.
    I hooked everything up last night for testing. Mach3 was configured so that pressing the arrow keys moves the x/y axis and page up/down moves the z axis. However when pressing these keys only 3 of the steppers turn. I know that something is just not setup correctly because if I assign hotkeys to each motor I can get them all to turn.
    Can anyone tell me how to setup the Y axis for multiple motors? Also how I could get one motor to turn in the opposite direction for a table like this?
    Thank you!
    Jan 2010
    2141
    I don't have Mach3 running right now, so this is just from memory.
    There is a configuration option to "slave" two motors together. Make sure that both motors are configured identically, then slave them. There is a separate "reverse" option that needs to be selected from the homing screen.
    Sep 2007
    64
    Thank you! Exactly what I needed to know.
    Dec 2009
    Slaving axis
    U will have to slave the y axis to one of the other axis in the mach 3 settings. I had the same thing happen until i found it on a forum. download the manual http://www.machsupport.com/docs/Mach3Mill_1.84.pdf and look at section 5.6.4 . Thats will show u what needs to be done..
  1. 4 Axis TB6560 pin setup in MACH3???
    By proph3t in forum Stepper Motors / Drives
    Last Post: 12-18-2012, 07:20 PM
  2. Z-axis setup/control in Mach3
    By Richotech in forum Machines running Mach Software
    Last Post: 08-10-2012, 05:49 PM
  3. mach3 Y axis 2 stepper 2 ballscrews setup
    By 15mgtar in forum Mach Mill
    Last Post: 05-01-2011, 03:02 AM
  4. G540 and Mach3 setup for dummies...
    By forrest39 in forum Benchtop Machines
    Last Post: 01-14-2010, 06:47 AM
  5. Mach3/Gecko G540 setup questions
    By mlabruyere in forum Gecko Drives
    Last Post: 12-14-2009, 11:05 AM
