586,801 active members*
5,151 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Mastercam c-plane boundry problem...
Results 1 to 11 of 11
    Jan 2010
    25
    Hey,
    Pretty new to mastercam. I want to use a pocket to cut this "neck pocket" for my guitar but am having trouble. Boundry doesn't lie in the construction plane. Is it because of the holes?
    your help is appreciated.
    Dave
    May 2004
    4519
    Most likely it is because at least one of the boundaries you have selected is not parallel to the construction plane.
    May 2004
    4519
    Looks like you are using Solids and 3-D for selection of boundary.
    May 2004
    4519
    Is the Face you selected parallel to the construction plane?
    Jan 2010
    25
    Quote Originally Posted by txcncman View Post
    OK I'll take a look later tonight. Should be parallel though.
    Yes, I tried to just use edge and select the edge chain. same thing happened.
    I would hope so. the WCS is the top Plane. and the cplane is top also. I have to confirm on the parallel boundary though. I'll check back later tonight.
    Apr 2003
    3578
    PS use solid edge , then also check loop along with Partial loop so you can do an open pocket using the outer edges but not the front of the pocket or the holes.
    Cadcam
    Software and hardware sales, contract Programming and Consultant , Cad-Cam Instructor .
    Jan 2010
    25
    Will check it out. Appreciate the advice.
    Thanks,
    Dave
    Jan 2010
    25
    cadcam, did what you said still giving me the error.
    Apr 2003
    3578
    Can you send me the file then I can tell you whats wrong. and I can even share a few of my guitars I had designed for a customer.
    Cadcam
    Jan 2010
    25
    Man you are quick. I investigated the model a little more and it isn't parallel two degree compensation. You guy's were right. Apologize for the stupid question. I have been using flow lines for surfacing. What tool path do you have in mind to keep the edges clean. flowline then maybe a contour?
    Apr 2003
    3578
    I like it. ps you have email
    Cadcam
  1. Replies: 1
    Last Post: 07-05-2009, 04:04 AM
  2. Problem with G02 en Plane X-Z with Mach3
    By mariano_mdf in forum Machines running Mach Software
    Last Post: 10-29-2007, 04:16 PM
  3. Mach 3 blip on boundry line
    By keen in forum Mach Software (ArtSoft software)
    Last Post: 06-23-2007, 12:49 AM
  4. Boundry Cuts?
    By 12jbowler in forum BobCad-Cam
    Last Post: 02-28-2007, 09:10 PM
  5. cycles initial plane/retract plane
    By HuFlungDung in forum OneCNC
    Last Post: 06-27-2003, 01:02 AM
