586,792 active members*
2,687 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > G540 Mach3 Display Issues & Slave Axis Issues
    Apr 2009
    7
    So the xml profile for Mach3 that Gecko provides takes my old CNC files and makes them look like swiss cheese. So I took all the settings and put them into Mach3's stock configuration and the slave Axis option does not power my A axis? I don't care which Mach3 profile I use so I just want to fix either problem so I can run.
    Thanks:}
    Apr 2009
    7
    figured out the slave axis issue....Outputs for the slave A axis were not set like the other motors.....oooops.
    I would still like to know why Gecko's profile for Mach3 makes my programs look like swiss cheese?
    Apr 2009
    7
    A axis slave solved
    Slaved A axis didn't have the step and direction pins programmed in the old version of Mach3.
    Still wondering how to get Gecko's Mach3 profile to not make my CNC programs look like swiss cheese....but I'll settle for the old profile working for now.
  1. SprutCAM 7 1.4 Display speed issues
    By dblox in forum SprutCAM
    Last Post: 08-01-2011, 11:54 PM
  2. chain graphics display issues
    By david martin in forum Mastercam
    Last Post: 06-10-2011, 04:51 AM
  3. G540 PC comunication issues...
    By CNC74 in forum Gecko Drives
    Last Post: 02-10-2010, 05:15 PM
  4. Display Issues - please help
    By jpf44 in forum Uncategorised CAD Discussion
    Last Post: 06-14-2008, 02:31 AM
  5. BP Series 1 with Mach3- Z axis limits issues
    By bbuonomo in forum Bridgeport / Hardinge Mills
    Last Post: 10-13-2006, 10:39 AM
