Can I turn on my spindle during set up when using a wiggler to find the center of a hole?
If so how?
If so how?
2008 Haas VF2D
OneCNC XR5 Mill Expert
Of course, MDI an "M3 S1234" "Write" and "Start". After that you can start and stop the spindle with the soft keys.
Or go into manual (Hand/Jog) type 750 and press CW or CCW. Reset or STOP stops it.
If on a newer machine you have to turn the key to SETUP and do the above with the doors open. It won't go higher than 750.
I have my MDI mode screen with a S1000 M03, all the time. After you start it at the designated speed, you can just hit the forward (CW) or reverse (CCW) button on the panel as Toymaker said.
One word of caution, make sure you have not run a program with a different rpm speed since the last time you used your MDI speed. Lost a nice co-axial indicator to someone hitting CW after a 7500 rpm program.
One other bit of info, when touching on some edges, CCW is easier to see the jump than CW. In that case just push the other button, takes only a second.
Mike
Good point, must have been a horizontal or a lathe.[/QUOTE]
No, 1998 VF-4. Don't think we ever found all of those parts!
Mike
Thank you gentlemen.
2008 Haas VF2D
