I have just purchased a Sieg SX2 and several accessories however when using the fine adjustment to drive down in to the work the head seems to get stuck then drop by a mm or so. I have set up a video of this however unfortunately the light coming form behind the machine was washing out the image. However you can see clearly the head dropping.
Sieg have responded saying that I am not using it correctly.
I have Lubed the slides, checked the adjustments and made sure there are not bits of swarf jammed in the guides.
[ame=http://www.youtube.com/watch?v=6Fmrn7sKduY&feature=feedfbc]P1020372-2.MOV - YouTube[/ame]
Any suggestions would be appreciated.
Regards
Andrew Hooper
