Hi everyone,
I have to machine 4 dies for cutting out biscuit (cookie) shapes.
They are from solid stainless steel 316..
Blank 120x180x45 mm
The shape is the outline of a fat snowman (not that this matters)
My problem is that the remaining wall is only 1.0mm thick !
and 18mm in height...
I am getting vibration marks and a bad finish.
My final cut is using a 4mm dia 4 flute cabide endmill TiLAN coated with 20mm flute length.
RPM 5845 FEED 0.02mm per tooth
I have to use the 4mm dia as the smallest radius is 2.2mm.
Can anyone tell me where I'm going wrong or suggest a better approach??
cutter??
Speed??
Feed??
Many thanks for any help guys. :-)
