Originally Posted by
txcncman
On shimming/trimming tool holders: This is something that you should not have to do in a perfect world. But a lathe can become misaligned for different reasons. General wear from use. Crashes. Settling. Ideally you want to put the machine back into the correct alignment. By doing so it not only will solve tool alignment problems, it will let the machine cut better, less chatter, and more accurately. If you do not know how to align your particular lathe, call in a machine mechanic to do it for you. Yes, mechanics can be costly. The ones I deal with charge $125.00 per hour. But a good mechanic can re-align a machine in about 3 hours. How much will that $450 spent now save you in time and headaches and scrapped parts in say the next 6 months? Unless a machine seems to be cutting perfectly, I tend to want to re-align them about once per year. More often if they have been crashed.
