586,396 active members*
3,090 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Conquest T 42 FANUC 0T optional parameters
Results 1 to 11 of 11
    Hi all
    Hardinge Conquest T 42 FANUC 0T system.
    I need the optional parameters 900-920. If someone has the same type of machine with this system I would be grateful to him to send me.
    Boban
    Hi all,
    I still did not find these settings, if you have someone who has the optional parameters of 900 to 920 would like to send them to me. Machine I still can not run.
    thanks
    Jun 2011
    9
    You are not providing enough or correct information. Hardinge T42 only sold with 18T control. You must have a CS-42, which was built with either an OTB and OTC control.
    I suggest you contact Hardinge with your machine serial number (located inside the headwall by the spindle). They keep all machine parameters on record, and will provide them for a fee (200$ was the going rate last I heard, but may be supplied for free if you are the original owner)
    Thank you Lewertek because you corrected me.
    Yes, it's only a Hardinge Conquest 42, I have two CNC lathe HARDINGE Conquest T42 with fanuc 18t system.
    I accidentally typed T.
    Thanks again.
    I contacted Hardinge but I can not find the machine SNo and they can not help me. I have no documentation of the machine, it is a major problem. I bought it without any documentation.
    24223
    PM me with email add., I may be able to help.
    Al.
    Jun 2011
    9
    For the serial number: Open the collet closer acces door on the front of the machine, look on the backside of the machine headwall, just to the right and in front of the spindle headstock, there should be a small stamped plate with a number CS-XXX.
    If it has been removed, I'd suspect it to be a stolen machine or else involved in some other fraudulent activity.
    24223
    Per email here is saving the 900's.
    Al.
    Attached Files Attached Files
    Today I finally got the original parameters of the manufacturer Hardinge.
    How was I happy ... but not for long ....
    First I deleted all parameters.
    Than I once again inserted the optional parameters until I reached the 910.5 parameter when the system again crashed.
    914 ram parity error (servo) reappeared at boot time.
    I repeated everything again and once again on the same parameter the system crashed.
    I suppose that it was a memory on the motherboard or axis card problem.
    Has anyone had experience with this already, and some easier solution?
    Sep 2011
    T-42 Conquest SP Lathe 900's Paramaters
    900,) 0011 1110
    1,) 1100 1000
    2,) 0010 0100
    3,) 1000 0100
    4,) ---- -----
    5,) ---- 0100
    6,) 0010 1000
    7,) 0100 1010
    8,) ----- -----
    9,) 0100 -----
    910.) 0110 -----
    11,) 1000 -----
    12,) ----- -----
    13,) 1000 ------
    14,) 1000 ------
    15,) ----- -----
    16,) ------ -----
    17,) ----- 0010
    18,) ------ ------
    19,) ------ -------
    Nov 2013
    I need help with these parameters, the team I formatting.
    Quote Originally Posted by bobancurug View Post
    Hi bob,
    Could you please send me copy of the parameters
    Sting
  1. Replies: 1
    Last Post: 02-04-2013, 12:59 PM
  2. Hardinge Conquest VMC 700 (GE FANUC 18M) - Worklight Problem
    By Krevv in forum Bridgeport / Hardinge Mills
    Last Post: 12-13-2012, 04:08 PM
  3. Hardinge Conquest T-51's Parameters required
    By Manpreet Singh in forum Hardinge Lathes
    Last Post: 04-08-2012, 08:20 PM
  4. Help on Fanuc 18m for Hardinge Conquest VMC 700
    By chuckblowers in forum Fanuc
    Last Post: 02-20-2012, 10:24 AM
  5. Replies: 0
    Last Post: 12-22-2010, 11:17 PM
